Bypass valve with a Blitz?
Old Jan 4, 2008 | 03:32 AM
proctorsilex's Avatar
Default Bypass valve with a Blitz?
have any of you considered installing a bypass valve with a blitz SC?
i am planning on reinstalling my blitz if i do not sell it by the summer, but i want to take care of a few things, the main thing being highway drone. second to that is the parasitic loss that i felt when the SC was turned off.
the blitz has no bypass, which means that the incoming air goes through the compressor regardless of whether the compressor is engaged. this needlessly makes quite a bit of noise and zaps NA power. i do not want to run high octane if i do not have to! i.e. long highway trips.
i am thinking that a bypass valve should prevent the compressor from spinning when not in use.
anybody tried it?
thanks!
http://www.magnusonproducts.com/bypass.htm
Old Jan 26, 2008 | 11:36 PM
EasysBox's Avatar
magnuson sells "universal" bypass valves... you could get one of theirs and attach it to your manifold and intake... should work just fine...
Old Jan 27, 2008 | 01:25 AM
SCIONFALCON's Avatar
i would like to try because my blow off valve set up didnt work so well the first try. i have ordered another one and gonna see how that works. but would like to know more about the bypass valve.
when i took the blow off valve off the check engine light went off with it. yeah...
Old Jan 27, 2008 | 04:58 AM
EasysBox's Avatar
hey guys, here is a link to the magnuson bypass valves... http://www.magnusonproducts.com/bypass.htm
Old Jan 27, 2008 | 05:08 AM
boostedbox06's Avatar
won't that throw off your a/f/r if you are constantly switching to and from use?
Old Jan 27, 2008 | 05:10 AM
haha! i guess that i should have had a not in the op pointing out the link to magnuson.
anyway, i am pretty certain that i will be doing this in a few months. i plan on talking with a shop that somebody recommended to do the custom work.
thinkin that an LSD is in order too. i can justify it because of snow and the occasional rallycross ;)
Old Jan 27, 2008 | 05:15 AM
air/fuel ratio? no, because the bypass valve is to be used when the pressure in the intake manifold is less than the pressure before the compressor, which happens when the compressor is OFF and, possibly, as magnuson wrote, when cruising (constant speed). basically, it opens up when the compressor is doing nothing for you but draining power and, more important to me, making a butt load of noise.
Old Jan 27, 2008 | 05:17 AM
btw, my mother's 2006 mini cooper s has one of these. i noticed the pathway from the intake that bypasses the compressor and got to thinking...
yupinmytC
22
Jul 27, 2024 07:08 PM
yhwhdesign
Jun 11, 2021 03:34 PM
steeze69
May 24, 2021 02:57 AM
6885BLM8435
Aug 19, 2015 03:08 PM
