Amps in Hatch???
Originally Posted by SuperCrunchyAction
You mean in the back of the car? I think just about everybody has at least their subs in the rear.
I believe he means in the actual hatch of the car which would be the 5th/3rd door. I havent seen anyone do it but its quite possible... wiring would be a real big pain though and i've heard the xBs hatch is actually quite flimsy and it does feel flimsy to me as well. Like i was saying... it would be a real pain to run 4awg wire or anything bigger than that to run a powerful amp. Just my two cents
Ill have to agree its a pain to run wires into the hatch. I had to run my rear view camera wiring through it since I mounted the cam in my third brake light and the plug on the end is about the size of 4awg wire. What I would suggest is to run a coat hanger through the grommet then put TONS of lithium grease into the grommet for lube. Attach whatever youre running through and itll slide through very easily.
i did that to my pathfinder back in 97...
to much trouble for anything worth while...
2 - 4ga wires + rca's + speaker wires + remote = a lot of wire lube and cussin'
it looked trick as hell, but not worth it to me anymore
a$$
when somebody says they have a hatch back do you go into siezures tring to figure out what the hatch is????
and if he said rear door, would you have thought the door behind the drivers door???
hatch or liftgate are proper terms to describe it...
