best HID kit for the tC
Originally Posted by FOBmarley
I bought my HIDs off ebay....they're the actual RX 330 HID bulbs and ballast.....once they were installed I had mad glare but aiming the lights down helps a lot.......and i don't just mean a lot but i mean like a lot a lot.....
The glare from our TC headlights are pretty noticeable. I think with some modifications in the way of an eyebrow like overlay would get rid of it. I was messing with this last night actually and was thinking of calling up BlueBatmobile to see if he can fab up something. If you go into a really dark room and shine the lights against the wall from 6-10 feet away or so you can see the diagonal line that is what would cause people to flash you. But as soon as you put an eyebrow on the lens it gets rid of it. The TC lights actually have a very straight line, not like a projector of course but it is pretty good none the less.
I was messing with that same idea about the eyebrow so i cut out a piece to cover where the most glare was...and it seemed to work fine...i think we should call up bluebatmobile and see if they can come up with something
I am amazed that anyone would worry about this since I drive all the time at night and never have been flashed with this set or my last set on my other car. Running 6000K and didnt adjust the beam pattern at all.
I do get flashed when I have used the HID High Beam part though.
The projector guys are correct. Projectors give a much better output. But honestly, I get tired of hearing them down talk those with kits just because they had over $1K to throw away on some headlights. Get off your high horses!
A retro fit is just as illegal! It is illegal to put HID in any car that does not offer an oem option. That being said, I personally want HIDs really bad. Retro fit would be my first choice if I come into some loot, but most likely i will go with the Techone kit because I've heard so many good things about it on this sight. The truth is I see cars with HID kits all the time and during the day the glare is no different from the star effect you get from projectors. At night they are bright but not even close to as bad as halogen highs. When cars with projectors are comming directly at you( from above or below your eye level) the light shines directly at you and its pretty intense for a second. I say all that to say this, everything glares a little (when I had silverstars I would occasionally get flashed), all HID for the tC is illegal (but so is the fact that I have no liscense plate on my front bumper), and in the end its about what looks the best for the amount of money your willing to spend( after all, nobody is doing this mod for safety reasons if they are really honest with them selves). All HIDs are sexy.
This is the way I look at it... if you're going to modify your car, don't you want to modify it with better parts? For example, getting properly tuned springs and struts are going to yield better results than cutting your springs. So if you're going to modify your headlights anyways, why not modify it to work the best that they can? If you don't want to spend the money, then I respect that choice.
Someone should try to design an HID conversion with a self-leveling feature. My dad's Prius uses a reflector type HID headlight. In the rear suspenion there is a leveling sensor that changes the angles of the headlights to reduce glare. There is a difference between non-HID and HID headlights on the Prius. The Prius uses bi-xenon headlights, meaning that the light works as low beam and high beam. Toyota acomplish this by adding a flap that covers part of the light during low beam operation. When you switch to high beam the flap retracts into the cone in front of the bulb.
Not to mention, the ballasts from the kit I want take only 7 amps of power from the stock wiring for the first five seconds to start the bulbs! Stock halogens take more than that. Probably means the lights take longer to warm up then other HIDs, but that cool delay is one of my favorite features
What about the time it takes to do a retrofit, not to mention the know how. If I'm not mistaken I think I read your right up maximus96, and it seemed very technichal and complicated, although very well detailed. Did you purchase a second pair of headlight housings to modify? If you did, I don't see how it could be under 350$. I don't think many people on this sight can have their tCs out of comission for having know headlights for any given amount of time.
Check us out if you get a chance - www.jlevisw.com
We've got pretty competitive pricing on HIDs ;)
JL
JL
S7ephavs
Mar 22, 2015 12:09 PM
umnitza
Dec 1, 2014 06:26 PM
