A/C led lights
Old Aug 3, 2005 | 06:55 PM
blitz_xb's Avatar
Default A/C led lights
im sure this has been asked before but ive been searching and cant seem to find it i want to change the stock amber leds to a blue but cant find them anywhere i tried blub dye but that turned out like crap
Old Aug 3, 2005 | 07:17 PM
bear454's Avatar
I put 3mm blue LEDs in place of the incandescent (sp?) bulbs on the HVAC controls - looks nice except for 2 issues:
* The LEDs are very tightly focused so the light has a visible center, and fades off on the outside edges. I've ordered some fresnel lens caps for the LEDS that should take care of this - I'll post when they show up.
* The dimmer is set up for incandescant bulbs in the HVAC, so the LEDS don't respond on a smooth curve like the other lights.
Old Aug 3, 2005 | 07:19 PM
bear454's Avatar
Also - the true blue makes the red part of the temperature control invisible at night - what with no red light coming from the lamp...
Old Aug 3, 2005 | 07:54 PM
blitz_xb's Avatar
how you go about installing them when it comes to electrical stuff im not to good
Old Aug 3, 2005 | 08:19 PM
Matts_xB's Avatar
Here is the tech article...
https://www.scionlife.com/forums/viewtopic.php?t=11283
It only takes about 10 minutes to do.
Old Aug 3, 2005 | 08:33 PM
Max2k's Avatar
You can file the ends off your LEDs to make them diffuse better.
Old Aug 4, 2005 | 02:21 PM
Oznium_com's Avatar
^ werd!
That is a good technique. Use a dremel, a metal file, sand paper, etc. File them down flat.
If you want 3mm or 5mm LEDs: http://www.oznium.com/led
Old Aug 4, 2005 | 07:29 PM
bear454's Avatar
I prefer http://www.lsdiodes.com/
Nice servce & great prices - don't be afraid to ask them questions!
Old Aug 5, 2005 | 03:32 AM
Oznium_com's Avatar
But Oznium.com is a SPONSOR here. And I offer nice service and great prices and am happy to answer questions.
And if you have any questions, I am easy to get a hold of:
AIM: philbish
email: phil at oznium com
Toll free: 800-245-8131
Cell phone: 925-683-1839
Old Aug 5, 2005 | 04:43 AM
Max2k's Avatar
And by the way, Oznium has a howto on changing the lights in a camaro's door switch that's directly applicable to the scion AC lights (same part).
Old Aug 5, 2005 | 03:07 PM
Shadetree's Avatar
Oznium,
While I did just order 50 bright green's from ya'll, there are a few things I do like better about that other site.
How to hook up LEDs
is well written and understandable for a total noob. Especially about hooking them up in parallel.
And their spec sheet for each LED has alot more information. Though I don't like their little disclaimer which I interpret as "If you don't get this exact LED it's not our problem"
Like I said, I still went with you (and will again) but I'd like to see more info listed for the LED's like is the listed mcd the max or the typical? What's the typical V for them instead of just the max V? Small things like that make me more confident buying sight unseen.[/quote][/list]
Old Aug 5, 2005 | 06:40 PM
Oznium_com's Avatar
Thanks for the order Shadetree. I agree, and will work on those 2 things.
horsefeathers
Sep 17, 2023 11:12 PM
airmankevin1
Feb 14, 2018 01:23 PM
ktb53
21
Jan 5, 2005 01:59 AM
crystaljukebox_com
39
May 14, 2004 04:55 AM
sithscripter
9
Sep 26, 2003 05:27 AM
