Dome Light Problem !!!
Old Apr 8, 2005 | 06:40 PM
MyBoX's Avatar
Default Dome Light Problem !!!
Hey Guys, I was working on my car and seems like it the two wires touched each other but the fuse was not blown. now after installing everything, the dome light is not working, so wondering if any one knows where the delay relay for dome light located on XB, Any help is appreciated, Sean
Old Apr 8, 2005 | 06:46 PM
dgHotLava's Avatar
i think its under the dash by the speedo...
i'll have to check when i get home...(and my isp is working tonight)
Old Apr 8, 2005 | 06:49 PM
MyBoX's Avatar
Thanks man, I know there two relay under there, Black and Red and both of them say DOOR RELAY on them but I don't know if they are are related to dome light, but thanks again for your help, Sean
Old Apr 8, 2005 | 07:38 PM
xBino's Avatar
Did you check to see if the bulb is still good?
Old Apr 8, 2005 | 07:48 PM
MyBoX's Avatar
Yep, I have the posetive side but there is no ground, so it doesn't show if the doors are open or close, since they have the switch for ground side, so Ithink the module is bad, Sean
Old Apr 8, 2005 | 07:58 PM
dgHotLava's Avatar
where are you testing the wires...the ground comes from the mounting screws of the dome light.
the two wires at the dome light are for constant power and a dimming power....(thats what i remember from doing my dome light...but its been a while...)
Old Apr 9, 2005 | 02:00 AM
MyBoX's Avatar
I was testing at two connector outputs, I know one is posetive for sure, and the other one as you mentioned is dimming (-) or also gives the negetive side when its on the open door/light comes on mode, so now I'm missing that negetive to the connector, which I think is comming from some kind of relay which is connected to door switches, so it would be awsome if some one knew which box/relay that is or where it is located on Xb, Sean
Old Apr 9, 2005 | 12:39 PM
dgHotLava's Avatar
i checked my manuals for the location...not much help...sorry
Old Apr 9, 2005 | 04:28 PM
MyBoX's Avatar
Thanks for checking man, Take care Sean
horsefeathers
Sep 17, 2023 11:12 PM
Jordly221
Feb 13, 2019 05:29 PM
XB06
May 30, 2015 02:42 AM
AdmirN
Jan 5, 2015 10:19 PM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
