Fog Lights Relays Not Well Documented in EWD (Elect Wiring Diagrams)
Old Jun 15, 2020 | 07:14 PM
mrmox's Avatar
Default Fog Lights Relays Not Well Documented in EWD (Elect Wiring Diagrams)
I am having trouble correlating wiring diagrams to physical placements.
I found a picture on ebay of front and back of the in cabin junction and fuse panel, but the EWD seems to omit some relays. See pictures:
EWD page 24
Front of panel
Back of panel
[Later Realization: See the 2 Blue Relays in the Back of Panel picture? The space BELOW them is where a FOG LIGHTS relay should go,
but the guy who removed this panel probably stripped the attachment off since it held no relay, I bet! This was a big contributor to my confusion]
I watched the video Brandon of Extreme Daily Drivers put up on Youtube for adding FOG LIGHTS to his xB and I want to zero in on the exact location to plug in that relay!
But I am stumped from this documentation (I have not crawled under the dash of my car yet though).
Any guidance?
Thanks!
- mrmox
Last edited by MR_LUV; Jun 16, 2020 at 07:12 PM. Reason: Added Fog Lights to Title Per OP Desire
Old Jun 15, 2020 | 09:52 PM
62Fender's Avatar
The fog light relay is directly under the headlight relay. Check your PMs when you get a chance.
Old Jun 16, 2020 | 04:34 PM
mrmox's Avatar
I got the (?) AUTOWIKI (Amazon Seller) FOG LIGHTS Working last night!
You probably know you have to insert a RELAY you buy separately into an empty (and kind of hidden) socket.
Bad luck: The only (eBay) picture I could find of an Instrument Panel J/B (aka Interior Fuse Panel) that had a BACK VIEW also had the FOG LIGHTS RELAY MISSING (see above, only 2 relays are hanging off).
I guess the way the relays are clipped/strapped/hung off the side of the Instrument Panel J/B meant they did not even try to identify them on that EWD Page 24 above. Page 24 shows 4 anonymous protrusions on the left,
the top 3 are RELAYS and the 4th is a unused connector? IDK! As many folks have confirmed, the 3rd relay (or empty socket) from the top is for the fog lights.
Since YouTuber Brandon of Extreme Daily Drivers got the RELAY inserted OK by hand, I decided I would too. But I failed until I took some Endoscope pictures that may help someone else so I will contribute them.
(Critical info is the VERTICAL | | lugs of the relay are at the BOTTOM of the socket) (hmmm they are only the VERTICAL lugs if you are holding the relay in Portrait orientation! So hard to remove all ambiguities!)
(the EMPTY socket is where the Fog Light Relay needs to go)
Old Jun 16, 2020 | 05:19 PM
mrmox's Avatar
Default And one more thing FOG LIGHT BEHAVIOR 2004 xB
Yes, you need to know that the Fog Lights will NOT TURN ON (for 2004 xB ) UNLESS:
Fog Lights Switch is ON
Headlights are ON
Headlights are NOT BRIGHTS
This clever BEHAVIOR is "obvious" if you look at the circuit:
Old Jun 16, 2020 | 05:52 PM
62Fender's Avatar
Glad you got them installed. Nice thread and pics.
Admit1
11
Mar 26, 2011 02:31 AM
Rezaxx
Aug 22, 2005 11:41 AM
mackenzie129
11
Mar 27, 2005 03:56 AM
smokyXB
Jan 24, 2005 09:13 AM
TrappedInABox
Dec 19, 2004 02:10 PM
