h/u stopped working revised
Old Apr 20, 2005 | 10:32 PM
lex990's Avatar
Default h/u stopped working revised
tried all the connections, all fuses on the scion, even changed h/u's to my old one and it still only pushes through the subs, It played for about a month and then just died i have already checked all the minor stuff i'm not that dumb
Old Apr 20, 2005 | 10:34 PM
pdrizzle's Avatar
DeepSouth Scions
Not enough information... amps? speakers? Explain the system in detail.
Old Apr 20, 2005 | 10:46 PM
lex990's Avatar
amp's speakers and everything else is irrelevant. listen to my problem. highs and mids not recieving music, they are not ran through an amp, they are wired to my h/u through my harness i got. just a normal stereo setup. h/u with 4 speakers into it, and amp and subs through rcas
Old Apr 20, 2005 | 10:55 PM
pdrizzle's Avatar
DeepSouth Scions
Your speakers are relevant; are they factory or aftermarket? Who hooked them up? You spoke about 2 different head units, what are the two? Is one of them the stock radio? How did you hook the speakers up to the radio? Did you splice the existing wires and connect them to a harness or did you run all new wires? The phrase "just a normal stereo setup" tells me nothing. There are so many variables that you aren't explaining how do you expect anyone to help you?! If you are as impatient with hooking up your stereo equipment as you are with explaining your situation to people trying to help you, my guess is you were careless and fried something.
Old Apr 21, 2005 | 02:23 AM
Big_Jim's Avatar
did you use a pioneer radio???
if everything is run through the radio and only the subs are playing, you most likely have a grounding problem with one of your speakers.
if its not covered under warranty, throw the radio out (depending on the model) and go buy a new one.
we def. need more information though, so keep us posted.
xBSciontist
Jun 18, 2019 03:06 PM
scionlife
May 4, 2017 07:13 AM
missing_image
Feb 7, 2015 07:18 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
cid_mcdp
Jan 5, 2015 02:45 PM
