How to wire subs
Old Mar 16, 2005 | 05:53 PM
SCI_TC_GUY's Avatar
let me know how it turns out.....PM me if u have any other questions....
Old Mar 17, 2005 | 02:48 AM
Twidget722's Avatar
you can also just connect the two subs together outside of the box, usually the easiest and the cheapest
Old Mar 17, 2005 | 03:10 AM
Scott17's Avatar
StyleWagons
Default Re: Ok
Originally Posted by RanmaP
Originally Posted by dgHotLava
first off, you can loose the wall between speakers...
or you can drill a small hole to run the wire through and seal it up with dum dum or silicone...
with 2x 4ohm DVC you can have 1, 4, 16 ohm results
the 16 is not a good option...
so 1 or 4 ohms...
make sure your amp is 1 ohm stable...most are not...mono block just means one speaker output but at what ohm???
It should be 1 ohm stable. Can range from 1.5 to 4 ohm
The amp has a total of 4 speaker output.
1.5 ohm is a lot different than 1 ohm. The amp probably won't like 1 ohm for long. 4 ohms should be the best for your amp.
Old Mar 18, 2005 | 09:35 PM
RanmaP's Avatar
Default Re: Ok
so 1 or 4 ohms...
I just caught that, I was even thinking to myself what the hell did I just wrote.
"My amp can handle 1.5 - 4 ohm and I said it should be good at 1 ohm"
Yeah... 4ohm is my route
Xaphoon
Scion tC 2G ICE & Interior
Apr 22, 2015 02:36 PM
dltjdgns66
Scion tC 1G ICE & Interior
Apr 15, 2015 07:59 AM
Zman
Apr 10, 2015 08:04 PM
TheSilencerTC
Feb 24, 2015 04:56 PM
DynamiteSJ
10
Nov 2, 2003 01:25 AM
