lowering the drivers seat
Hi guys, just wondering if anyone knows how to lower the drivers side seat of a 2006 xb by a couple of inches? I have done some searches but haven't come up with to much. I am not sure if there is a prefab bracket you can buy that your seat will bolt to or something like that? Any help would be greatly appreciated. Thanks!
The stock brackets are welded to the seat sliders, so your only real option is to change the sliders, and possibly the whole assembly.
I did some searching and it looks like Toyota Echo seats have the same mounting points (they share the same chassis as the xB), and the seats sit lower in the car.
Compare the xB seat bracket rear with the same place on the Echo.
xB:
Echo:
As you can see the xB has a "riser" that brings the seat up roughly 2". So if you can find a set of Echo seats you can probably combine the piece from those seat tracks with your seat tracks to get yours lower. Plus as a bonus the Echo seats should come with the storage tray under the passenger seat.
If that isn't low enough for you then you're probably looking at custom modifying both the brackets and the floor due to the floor brace the front of the seat bolts to.
xB:
Echo:
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
carid
Feb 12, 2015 11:54 AM
