Need help with Valet 712t keyless entry
I've got it installed but can't seem to get the unlock to function. Does it require a double pulse? I tried to reprogram the unit for double pulse but it refuses to go into reprogram mode. Can anyone help?
To get in to programming mode: Turn key to run position and back off, tap the Valet switch 5 times, hit valet one more time and hold. You should get 5 horn honks or LED will blink 5 times, to let you know you are in feature 5. Press the unlock button on remote and this should turn the Double pulse unlock on for you. Make sure the Yellow ignition wire is hooked up or it will never go into programing mode.
Thanks for the fast reply! I'm doing exactly as you (and the instructions)said for the reprograming but it ignors me. I'm putting power to the yellow then off. I then hit the valet button 5 times then hold in but get no responce from the LED.
Originally Posted by tbone587
yes it does require a double pulse, but u should be able to just hit unlock twice to see if it works.. If its not working then u may not have the right wire tapped into .
I don't want that feature so I normally don't have the yellow connected but when I do power it to attempt reprograming, it does lock.
Since no one has a solution to reprogram, does anyone know if the unlock trigger from the rt side switch is also double pulse? I was thinking I could tap into the green/black wire instead of the blue/yellow.
umnitza
Sep 1, 2015 08:06 PM
Armystrong
Aug 31, 2015 08:19 PM
712t, entry, horn, instructions, keyless, mode, model, programming, remote, reprogram, stopped, transmitter, valer, valet, working
