Problem with my turn signal, Help
Old Mar 20, 2007 | 12:04 PM
JCool's Avatar
Default Problem with my turn signal, Help
I have a problem with my turn signal, but I don't know what. Here is the situation..My left turn signal doesn't flash in the dash signal, and I check both outside, the left turn signals don't flash at all. The right side is working both inside and out...I hope anyone can help me, thanks..
Old Mar 20, 2007 | 05:45 PM
JCool's Avatar
help anyone?
Old Mar 20, 2007 | 06:12 PM
oldmanatee's Avatar
Not a clue, but I didn't want you to think you were being ignored...
Old Mar 20, 2007 | 06:36 PM
dagarhart's Avatar
Scionetics
I would check the bulbs. Then maybe the flasher unit. Other than that, I have no suggestions. bulbs do go out and do weird things to cars.
Old Mar 20, 2007 | 06:37 PM
UV7's Avatar
UV7
It's more than likely just a burnt turn signal bulb. since the bulbs are dual filament, they will light, just not flash. Try replacing the turn signal bulbs, one at a time, and see if that doesn't fix your issue. If that does not solve the issue, you may have a blown fuse or dead turn signal flasher. Both are easily (and cheaply) replaceable.
Old Mar 20, 2007 | 07:12 PM
JCool's Avatar
thanks..i have order the flasher and turn signal bulb already...it just so weird that the right side is working fine both inside and outside..
Old Mar 21, 2007 | 01:51 AM
TerribleTed's Avatar
It could be in the turn signal switch itself as well. That is more sucky tho ...more trouble to fix.
xBSciontist
Jun 18, 2019 03:06 PM
randomsuper
20
Jun 13, 2015 10:56 AM
Opr8r
20
Feb 25, 2004 11:29 PM
DJ_OVERGOLD
Dec 22, 2003 03:53 PM
Opr8r
Dec 11, 2003 07:35 PM
