thinkin about baggin the boX
Old Sep 14, 2005 | 04:06 AM
JDMJim's Avatar
another thing I have been thinking I would change is mounting the solenoids to the tank instead. For now, I ran lines down to the solenoids and I see that as six more potentials for leaks. They add up quick you know. I have noticed the JDM kits have very small solenoids. I don't know about other kits out there, but Japan uses small ones. I have also founs a leveling system from a company called Roadstorm. They have an impressive strutbag for the front. They look as if a Contitech bag has been put on a normal strut. I have not found a website yet.
Old Sep 14, 2005 | 04:26 AM
krazylowgsx's Avatar
is it my turn to chime in?
I have ES front air struts and Slam Specialties in the rear with FBI brackets. Ever since i got rid of the ES sleeve bags in the rear, i haven't had a single problem! The fronts make a bit of noise, but ES is working on fixing that, and will most likely fix or replace everyone that has rattles (which i think thats all of us). This is the info i got from Aaron (manager) at ES last time i talked to him.
Like someone mentioned.... You could complete your bags in a weekend if you know what your doing. if you don;t and plan on installing it yourself, i would do all the research you can before the install. ask as many question as you can about things your not 100% on.
The ES fitting have "O" rings in them, and i've been told that after time, the O ring wears out and can cause a leak.
I didn't like the way the 'hard' line took bends, and i didn't feel comfotable with it on my car. Alot of people give me ____ for the type of line, fittings, and clamps i used, but i've only had 1 minor leak, and its been fixed. I used normal air line that you would find in a shop running air tools. Its rated at 800psi burst, and VERY flexable(which is my main reason for using it)! I used barbed fitting with clamps, and like i said... I have only had a small leak, and it was at a gauge which diesn't use the barbed type fitting. Some say its ghetto, but whatever. I used it, i haven't had any issues with it, and it reduced the amount of fittings(more places for leaks to occur) i would have normally used with the hard line. When i did my install, i did it right.... i only wanted to do it once(which was a retarded thing to think since i was using ES rear sleev bags-ewww).
To all of you that have leaks..... check your gauges. I checked, and checked the line, fittings, valves, tanks, everything, and i didn't have a single effin leak, and it turned out to be behind the gauge! now when i leave my car aired up over night, the front pass. side STAYS UP!
bBOXD's Avatar
Autofashion in San Diego.
www.AutoFashionusa.com
Old Sep 14, 2005 | 04:32 AM
shortbus05's Avatar
definately bag bro... My kit was around 2,200 and worth every penny. http://www.clubstlscion.com/mgallery...s05/bagged.wmv
not the best quality but you can get the jist.
Old Sep 14, 2005 | 06:48 PM
rebelMan's Avatar
KAD
lol terrible video quality but thanks! what parts do you use? Also, is that how bags work? Like, it seems like u hit the switchs a couple of times to drop it, instead of like hitting it once to completely dump it out. Sorry i'm a n00b
Old Sep 14, 2005 | 06:58 PM
dAbOkZ's Avatar
yeah i am too. anything u might wanna tell us noobs b 4 waisting 3Gs on a kit please let me know. cuz by the looks of it its gonna be aound 15hundred. i saw the easy street kit for around 24 hundred.crayonBOX says his was about 15 hundred so ill go w/ that one. all i gotta do now is save up all the money of my life. lol. again, thanx for all the imput guys. also i have 17s on my car now and i was wondering if its a good idea to upgrade to 18s or 19s when i get bags. is it a good idea?
Old Sep 14, 2005 | 10:00 PM
sciondrgn's Avatar
Uness I come accross a great deal on some larger wheels Im doing 17's on mine
Old Sep 14, 2005 | 10:17 PM
Spider13's Avatar
The offset and width of your wheels is more important then the diameter. If you are running 17x7 et40 you'll be fine. If your running 17x9.....who knows. Also with some creative tires, you can get lower on smaller wheels, without cutting.
Also there is no real reason to spend more then 2k on a kit. Only reason I could see this being not true is if you go and buy some huge compressor.
Old Sep 14, 2005 | 10:20 PM
swartzy999's Avatar
do 19's......looks the sikest and cleanest!.those air runners are the way to go because a set of bags from anywhere else voids your warranty and they have to cut and weld. air-runner requires none of that and there is a check valve so if your compressor goes out u wount loose any air opposed to a set of bags, if ur compressor goes out ur stuck dropped.. you can get a set installed at auto fashon for 3500 out the door...good stuff !!!!
Old Sep 14, 2005 | 10:57 PM
sciondrgn's Avatar
FBi's Kit is No Cutting or Welding
Also I have a Fill Port on My Tank so if the compressor goes out i can use my home compressor to fill the tnak..
And from these Post Someone Mentioned the Air Runner used Firestone 2500's in the rear so Why Would I pay that much when I can purchase the Firestones and do the work myself a lot cheaper
Old Sep 14, 2005 | 10:58 PM
peabe's Avatar
well from all the info ive gathered. you can get the easy street fronts and the FBI rears, so they're bolt on. no cutting.
Old Sep 14, 2005 | 11:53 PM
Sittin_Pretti_Box's Avatar
ES up front and FBI stuff in rear, you have to do no cutting what so ever. Air Runner can void your warranty too, just like any other aftermarket product. Viair and Firestone compressors, and basically any compressor I know of for air suspension, all have check valves.
When it comes to hitting the switches, you hold the switch down or up to do what you want. Its not like hitting a button and it doing all the work at one touch of a button, you hold the switch to allow the current to power the valve to stay open.
Now... for Auto Fashion... their site sucks, i haven't seen any info on anything on their site, haha. (Had a tough time getting through the site)
Old Sep 15, 2005 | 12:52 AM
dAbOkZ's Avatar
sound str8! thanx buddy. ill definetly keep that in mind. i dunno about this auto fashion place....never been there. i live in gaithersburg, md and i never heard of it. ill def look 4 it and c what i can do. 3500 installed sounds like a good price installed w/ everything so i think ill do that. ill research airrunner brand too.
plus ill def consider slappin sum 19s on my box. sometimes my 17s look a lil small. u can see from the pix in my profile. plus im gettin a lil bored of my car. maybe ill get sum 19s 1st and then get the whole bag project thru.
like i said b 4 i am gettin too bored of my car... ill probably not ever have enuf money to spend on my car cuz just today i had a few hundred bux and i spent it all on ebay in like 3 minutes... modding my box in now a bad habbit!!
Old Sep 15, 2005 | 12:55 AM
peabe's Avatar
autofashionusa.com
i think maryland to san diego is kind of a long drive.
Old Sep 15, 2005 | 01:33 AM
Thats $3500 just for the kit, you install it. or pay someone else.
Old Sep 15, 2005 | 01:43 AM
dAbOkZ's Avatar
ohh damn i thought that price included installation and everything....how much does installation go 4?
Old Sep 15, 2005 | 01:49 AM
free if you do it yourself, if you know what you are doing, all it costs you is the parts, any other extra part, time, and some beer.
If you take it to a shop, make sure they know what they are doing. I think $700 is good, but it depends on who it is, i can't really say. If you lived here, thats what the guy who helped me do mine would probably charge you and he KNOWS what he is doing. But I'd say it should really cost no where over $1000.
Old Sep 15, 2005 | 02:00 AM
swartzy999's Avatar
the air runners are 3000 and instalation is 500.
the guy who owns auto fashon has his xa on the cover of i think it is import tuners.. i hate xa's and this one actualy lookz sik! the guy does really nice wrk and has a awesome showroom.. look for yourself at www.autofashionusa.com
Old Sep 15, 2005 | 02:06 AM
swartzy999's Avatar
hey dAbOkZ,
your ride would look extremely good with just putting 19's on it.. i looked at ur pro and saw ur lowering spring set-up. 19's would make it look slammed!...i personaly would go with black center and a polished lip.. good luck buddy and have fun!
Old Sep 15, 2005 | 02:44 AM
Spider13's Avatar
Just about all of this is wrong. Air runner is just as likely to void your warranty as anything else. Most of the kits on the market are bolt on and require no cutting or welding. All Viair compressors have a check vavle built into the leader hose. You should be able to get F/B/SS bags installed anywhere in the country for less then 3k. I'd bet more like 2500.
