Yes, another Rear Disc Brake post!
Old Feb 5, 2008 | 12:06 AM
  #161
bB2NER's Avatar
Music City Scions
Oh, that is not as bad as I thought it would be. I can do each spoke at a time on my bench grinder till they clear.
Old Feb 5, 2008 | 03:52 AM
  #162
AllianceAutoSports's Avatar
Music City Scions
.093 (or there about) is what has to be removed from each hub spoke to work. I hope to have this done and on in the next week. I have to say I have one of the OTHER conversions right now that I am REWORKING for someone, and all I can say is very crude materials were used. I am making new caliper brackets (they don't even fit the xB hub), and reworking the rotors (they don't fit the hub), and might have to modify the actual caliper bracket that comes on the caliper for it to work. And it was sold as a direct fit! This is one thing I can promise everyone watching this post. Mine WILL fit! And WILL be a complete bolt on kit. Bare with me as I am in the final stages of this conversion, and when its done you won't be disappointed. Then comes the big brake Wilwood Kit, which after all the R&D put into this one should be an easy conversion. Just not as cheap!
Old Feb 5, 2008 | 06:15 AM
  #163
BurxBox's Avatar
Thanks for the update.
Can't wait
Old Feb 9, 2008 | 05:09 AM
  #164
BurxBox's Avatar
^ +1
Old Feb 9, 2008 | 11:50 AM
  #165
Music City Scions
Originally Posted by xB-SS
per mikes a or b choices
if replacement rotors could be put on without any mods then choice b is perfect
grind the hub spokes and be done
Well, this is somewhat true. But the pilot on the hub and the pilot on the rotor are different, so some grinding would need to be done on the rotor there as well. I can let you guys know how much, but it is very little!!! My big thing for just going with turning the hub down is that the rotor hat is untouched. I have one side done and hope to go in tomorrow to finish the other. I will take some pictures while I'm working on the other side, so you guy can see what has to be modded to the rotor. I did end up going with an aftermarket e-brake cable and all I can say is it is SAWEET! I can't wait to get this installed!
Old Feb 9, 2008 | 09:06 PM
  #166
WTFxB's Avatar
Originally Posted by AllianceAutoSports
I did end up going with an aftermarket e-brake cable...
Man, that sounds great. When I had the Corolla GTS rear calipers, I could not figure out a way the factory xB cable would attach to the caliper e-brake lever. I had the correct caliper end and the correct handle end on two different cables, but never the same cable.
Did you find one somewhere, or have to make one? You are doing some seriously good work either way.
Old Feb 10, 2008 | 09:28 PM
  #167
swartzautoman's Avatar
i cant belive ive never seen this post befor, FINALLY is all ive got to say.
i think option B would be best because if i ever had to replace the rotor, i could just go to a parts store and pick one up.
keep up the A++ work, its looking great.
Old Feb 10, 2008 | 10:01 PM
  #168
Music City Scions
Well, I got the two hubs done today along with the rotors, and one caliper bracket. The rotor still has to be modified to fit the hub, even after the spokes are cut down. The hub pilot that the rotor slips over is .050 to small. The xB hub pilot is 2.17, the Corolla rotor is 2.125. It could be easily done at home too, if the rotors ever need to be replaced! Otherwise I will be machining up about 20 sets of rotors, after everything has been tested and working the way it should. It looks like I may still have this on before the end of the week!!!!!!
Old Feb 10, 2008 | 10:18 PM
  #169
im a good DIY kind of guy and wouldn't have any problem with working the rotors myself, i just think it would be easier for most people that can't or don't want to.
Old Feb 10, 2008 | 10:26 PM
  #170
bB2NER's Avatar
Music City Scions
X2 Thanks again Mike. I just hope by the time these are ready that Joanie lets me buy some now.
Old Feb 11, 2008 | 03:12 AM
  #171
Music City Scions
Well, gonna order another set of rotors tomorrow, With the Corolla rotor on, The caliper hits the swing arm before it makes it to the mounting holes on the caliper brackets. I have another rotor I was using before I got this other conversion to work on, so I decided to switch rotors to the same in that kit. BAD CALL! This may hold me up a day or so waiting on rotors, but I wanna do this right. My goal is to get this on, test it for a couple weeks then make up some kits. And for those of you in the Southeast going to the ST. PADDY's Day Scion Show in Atlanta, I plan on having kits available there as well!
Old Feb 12, 2008 | 02:58 AM
  #172
Music City Scions
Ok, Toyota Corolla GTS calipers mounted on well, we'll leave it at that at the moment!
Next is the new e-brake cables. And get rid of the make-shift caliper brackets for some nice CNC'd ones!
Old Feb 12, 2008 | 03:11 AM
  #173
jct's Avatar
jct
can't wait too see the final results
Old Feb 12, 2008 | 03:24 AM
  #174
INFINI's Avatar
yeah looking promising dude!
Old Feb 12, 2008 | 12:09 PM
  #175
latinotke639's Avatar
man that looks awsome, what is the estimated price range again? i would love to have some but done know if the wife will allow it right now
Old Feb 12, 2008 | 12:54 PM
  #176
gota love being married!
Old Feb 12, 2008 | 02:22 PM
  #177
burstaneurysm's Avatar
This is so cool... can't wait to see the finished product.
Old Feb 15, 2008 | 03:10 AM
  #178
Music City Scions
Ok, the one pc caliper brackets are DONE! Now the actual caliper bracket that comes with the caliper has to be modded. Hope to have that done tomorrow at luch. Then I can mount it on my workbench swingarm to make sure everything works like it is suppose to. I really can't mount the e-brake until I take my center counsel out, so I'll be driving without the e-brake for a few days. Until I get it all hooked up. Well, here are a couple pictures of the one pc. brackets:
Old Feb 15, 2008 | 10:52 PM
  #179
Kyle13's Avatar
Its looking really good AllianceAutoSports. I can't wait till its all finished.
Keep up the good work.
Old Feb 16, 2008 | 01:37 AM
  #180
Music City Scions
I will post some pictures tomorrow. I've been at work since 5:00 this morning. Went in early and stayed late, but the rotors, calipers, modded caliper brackets, and my caliper brackets are DONE!!!!!!!!! Ebrake is hooked up to one caliper. Now I plan on mounting it the box, then finish the ebrake while I drive it. It turned out really nice!!
