Help My HID's :)
Old Jan 20, 2007 | 01:19 AM
ayS's Avatar
ayS
Originally Posted by dugzillaxb
your high beams get power from the oem harness, you are not getting power to the ballasts. You either don't have the harness wired correctly or a connection between the oem harness or to the hids is wrong.
I can't believe you are having such a hard time. once I mounted the ballasts it took like 5 minutes to plug everything else in.
Did you look at the installation write up that cliff posted?
no i didn't. can i get a link? to his thread? i'll check the connections. but then again. the connections are the only obvious ones. male and female connections. the connection between the bulb and ballasts. i also mounted the double sided sticky tape it came with to the ballast to the frame. what part of the connection of the HID do you think i have not corrected correctly? i dont know if this would be okay as well.
also does the oem rubber cover go back on?
Old Jan 20, 2007 | 01:37 AM
dugzilla's Avatar
yes the cover goes back on. I think you can find the write up on his website, mobilehid.com
Old Jan 20, 2007 | 01:43 AM
ayS's Avatar
ayS
do you or anyone else have a pic of the engine bay, installed a HID kit? i want to see if it is simliar to mine. i'm following the instructions. checked everything. maybe if i swap the HID's left to right and right to left?
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
hondajt
Dec 14, 2015 12:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
