issues with HIDs
Old Jan 30, 2007 | 08:03 AM
808scion's Avatar
Default issues with HIDs
ok heres my problem. i jus installed an HID system to go with my Anzo projectors. i wired the HIds up using a relay and harness. when i fire up the HIDs with the radio on, it makes a like a static noise for like a second. when i fire up the HIDs with the radio deck off, it does NOT make any noise. any ideas. fyi...the HIDs work fine either way
Old Jan 30, 2007 | 08:17 AM
xBtenchu's Avatar
The radio makes a static noise? You make sure everything is grounded properly? I don't know about HIDs but I know car audio components that are improperly grounded can create 'interference' through the stereo. I'd check to make sure you have a good solid ground, preferably bare metal (painted metal wont ground as well.) Try maybe grounding it on the negative terminal of your battery and see if that helps. Only thing I can think of, hopefully someone can help more!
Old Jan 30, 2007 | 09:34 PM
hotbox05's Avatar
ground loop somewhere.
Old Jan 31, 2007 | 12:17 AM
Withaquicknes's Avatar
be careful not to fry your electrical system
Old Jan 31, 2007 | 07:17 PM
808scion's Avatar
havent tried grounding it to the negative terminal yet. might jus have to seek some professional help on this one. thanks for the info
S7ephavs
Mar 22, 2015 12:09 PM
GoodVibes
Mar 10, 2015 04:29 AM
clickclickw00t
Feb 18, 2015 08:57 PM
mvez
Scion tC 2G Aero & Exterior
Feb 4, 2015 01:15 AM
tc_Jake
Dec 31, 2014 01:45 AM
