LED Daytime Running Lights- DRL
Well I bought a pair of LED DRL of eBay, that replaces the cover for the factory Fog Lights. Since I wanted them to Turn on with the Ignition, I hooked them up that way. Real easy install and simple.
Guess I'm too lazy to turn them on and off manually
All you have to do is run the Positive and Negative wire into the interior. Get a Eaton Bussman Fuse Tap model HHH ATM. Remove the 15 ACC fuse and put in the fuse tap.
Add another 51 fuse in the fuse tap and then connect your power wire to the fuse tap and also ground your Negative wire. And plug the fuse tap into the ACC slot.
Voila. DRL come on with ignition.
___
___
___
