better shifting!
Old Dec 9, 2008 | 02:13 PM
whitebreadbox's Avatar
Default better shifting!
i know a lot of you have already changed your manual tranny oil to get better shifting. i did this with royal purple at around 5000mi and it got a bit better. got the trd shift kit and nst bushings and it improved a bit. it still wasn't where i wanted it... expecially when its cold outside. last week i decided to give redline MT-90 a shot. WOW its like butta!!! now, seeing as redline did such a great job with the tranny, i'm thinking of swapping to their oil, too. (using royal purple).
just wanted to let you all know that i've had great success with redline!
Old Dec 10, 2008 | 02:05 PM
AAG's Avatar
AAG
DeepSouth Scions
+1 on the mt-90, works really good.
Old Dec 13, 2008 | 08:49 AM
srb219's Avatar
how many quarts of Mt-90 do I need? Good web site to purchase?
Old Dec 13, 2008 | 12:13 PM
3qts and check with summitracing.com or jegs.com
Old Dec 17, 2008 | 09:01 PM
renegade4x4's Avatar
anyone have pics or tips or tricks on how to do this? I received my oil today and havent looked at it yet but i figured i wouldnt go into it blind. What tools do i need.
Chris
Old Dec 20, 2008 | 08:52 AM
srb219's Avatar
white, thanks for the info summit racing has in stock. Going to try and change myself
Old Dec 20, 2008 | 05:06 PM
Chris
there are 2 plugs on the tranny. both are the same size (24mm or 15/16" i think) one faces the drivers side at the bottom of the tranny. the other is on the front and has a sticker on it that says to refer to the owners manual. loosen top plug and pull the bottom one. then loosen top one to allow the vacuum to release allowing the fluid to come out faster. once done, re torque bottom one and leave top one out. the best way to do it is a long piece of hose and a funnel. run the hose/funnel down from the engine bay and insert into top plug. fill till fluid just starts to come out the top plug. to check, stick a finger in there like a dip stick. once its full (almost 3qts) reinstall the top plug and re torque it. clean it up, look for leaks and enjoy.
Old Dec 21, 2008 | 12:49 AM
thanks! shifts good! i notice a difference. there is also a how to in the tc forum and you remove the reverse switch to add fluid. very good mod!
chris
Old Dec 21, 2008 | 01:01 PM
glad to hear that you got it done and got the same results. its amazing how normal the shift feels until you do something to make it better...
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
Pkdust
Oct 20, 2015 04:27 PM
user9430961
Sep 24, 2015 01:09 PM
TheGovernmenT
Sep 4, 2015 11:57 AM
Wrencher
Jul 29, 2015 03:51 PM
