Are there any bulletins on the xB A/C? I'm seeing the same issue across 2 cars
Old 08-10-2018, 12:26 AM
alank2's Avatar
Default Are there any bulletins on the xB A/C? I'm seeing the same issue across 2 cars
I've got an 08 xB and 15 xB and both have the same weird problem. When it is hot (95+ degrees), the A/C does not want to work the first time you use it for the day. It will blow hot air for miles and miles until it finally decides to run and begin cooling the air. Both cars have done this. I swapped the A/C amplifier between them and one box seems only slightly better than the other, but both boxes do it. Something about this just smells of a common issue that I have to wonder if there is a bulletin on.
alank2 is offline
Old 08-25-2018, 08:17 PM
Tperry1786's Avatar
I'm having the same issue! Don't know wtf is going on
Tperry1786 is offline
Old 11-02-2018, 01:24 AM
Krysune's Avatar
I am really glad I am not the only one with this problem...The A/C literally works when it wants too...I have yet to figure out what the problem is myself.
Krysune is offline
Old 11-02-2018, 06:31 PM
Big_Jim's Avatar
have you all checked your low and high side pressures?
Big_Jim is offline
Old 11-03-2018, 11:55 AM
RichBinAZ's Avatar
I had to google what an A/C amplifier was. One Toyota site said there was an adjustment ****??? IDK could be all bogus
Our 2009 works fine in PHX heat... Does the clutch not engage then?
RichBinAZ is offline
DJApocalypse
30
11-29-2014 12:54 PM
shinjakuroi
02-12-2008 04:02 AM
27300man
06-22-2006 10:46 PM
Pojodan
04-20-2006 07:27 AM
scionjeremy05
09-03-2005 03:46 AM
Quick Reply: Are there any bulletins on the xB A/C? I'm seeing the same issue across 2 cars
