2011-2015 Scion Stereo Fit into 2008-2010?
Old 05-04-2018, 07:46 PM
Bluexb2's Avatar
Default 2011-2015 Scion Stereo Fit into 2008-2010?
Hey Everyone,
I'm looking at putting one of the newer Scion screen versions of the stereo with Bluetooth. Does anyone know if they will also fit the 2008-2010 models?
I want a stereo screen that fills the entire area without the need for the mounting system that fills the sides with ugly plastic. The stock ones look much nicer IMO.
Thanks for the help.
Bluexb2 is offline
Old 05-16-2018, 03:31 PM
Rattso's Avatar
Hi, I installed a PT546-00160 from an 2016 FRS into my 2008 xB. In addition to the radio and bluetooth I also added nav and backup. Everything works great except there is no button illumination. I have tried finding a solution but no luck so far. There are other installs of the PT546-00140 and the install is the same except for the 160 uses a different GPS antenna and the backup needs a 28 pin harness which is available from autoharnesshouse.com
If anyone has any ideas about the illumination issue I would very much appreciate it. If someone has the pinout of the PT546-00160 that would be great!
Rattso is offline
Old 05-22-2018, 08:41 PM
JeffLange's Avatar
As Rattso said, the newer radios will mount and fit in the 2008, so no worries there. Most of the wiring will also be similar as well, but potentially with some differences (for nav to work, etc.).
Jeff
JeffLange is offline
Old 07-10-2018, 07:44 PM
gedster314's Avatar
The radio from the IM will fit too but the wiring is a little different than of the 2015 XB too. I liked the sound profiles better in the 2015 radio than the IM radio. I was pretty happy with the IQ sound profile in me XB.
If you decide to go this route, when looking at ebay ads and car-parts.com ads, look at the pics of the back of the radio. You may get lucky and get the navigation module with the radio for the same price or just a little more. Try to get the jumper harness with it. Then you just need a $14 GPS and tenna from Ebay and you have a working nav system. The radio install is pretty easy.
If you are in SoCal, hit me up. I think I may still have the IM radio and maybe a 2015 radio. I may have an entune nav module too but that may have issues getting it to work with the phone app because you have to sign up with Toyota.
gedster314 is offline
Old 04-02-2023, 03:23 PM
MangaTheBarber45's Avatar
did you have to buy or add anything for the nav to work?
MangaTheBarber45 is offline
Old 04-02-2023, 03:39 PM
Rattso's Avatar
If you want Navigation and/or apps, here are your options:
  • PT296-00140 = Scion Aha + Navigation
  • PT296-47130 = Toyota Entune + Navigation (newer version)
  • PT296-47120 = Toyota Entune + Navigation (older version)
  • PT296-47121 = Toyota Navigation only
All of these will require a $10-15 GPS antenna (you just stick it behind the radio in the dash) and will need a special "Y" cable (around $25 if you don't get it along with the module). Prices range from $80-200 just depending on the weather and the model you want. Note that Toyota modules work fine with the Scion unit and vice a versa, but the module will change the color of the interface based on the brand you install (Scion = orange, Toyota = blue)
The harness to connect nav to HU PT296-47120-AB
Rattso is offline
skrappi
08-21-2017 01:19 AM
fatngs
04-02-2016 05:33 PM
blazeplacid
19
05-15-2007 05:31 AM
chazm
Scion tC 1G ICE & Interior
15
12-11-2006 03:17 AM
Granth77
11-25-2003 12:11 AM
Quick Reply: 2011-2015 Scion Stereo Fit into 2008-2010?
