AGM battery
Old Dec 21, 2013 | 07:04 AM
lookitsandrew's Avatar
Default AGM battery
hello i have a t1000 rockford fosgate hooked up on a 12 inch L7 and i want to add jbl p660c comp speakers with another amp rockford fosgate p400.4. i know i have to have the big 3. i just need to know what battery should i get?
Sent from my B1-710 using Tapatalk
Old Dec 22, 2013 | 03:33 AM
Greg S's Avatar
Unless you are planning on running the system with the car off for long periods of time it won't matter. The car runs on the alternator when the engine is running so that is supplying all the power to the eletronics. If you still want to upgrade the battery I highly recommend the Odyssey battery line. I've run them in my last few cars and really like them.
Old Dec 22, 2013 | 10:29 PM
Thank you glad I didn't get one
Sent from my SGH-T999 using Tapatalk
Old Dec 23, 2013 | 09:49 PM
xseveredveganx's Avatar
Utah Scions
If your voltage drops, I'd recommend possibly adding a second battery. I added an XS D3100 to my xB, but I'm also running a 3000rms amplifier.
The additional battery helped greatly.
Old Dec 24, 2013 | 08:00 PM
Greg S's Avatar
If, like xseveredveganx, you are drawing more power than the alternator can supply then definitely upgrade your main battery to an AGM one. They will handle the short term draw of an amp better than standard batteries. A second one can be warranted when you start going to way too much power levels but try to keep the two batteries matched in style, size, and age so that they charge evenly and remember that having two batteries will put more of a stain on your alternator to keep them both charged. It is also a good idea to have an isolator and run the system off the second battery so that it cannot drain you starting battery. I personally haven't run a second battery in years but I also haven't run over 1000 watts in power for years. Just don't need that much power any more.
yupinmytC
22
Jul 27, 2024 07:08 PM
drgonzo92
14
Apr 24, 2019 07:27 PM
knuckleheadjcz
Dec 24, 2015 09:07 AM
Geedavell
Scion xD ICE & Interior
Sep 28, 2015 01:33 AM
spharr62
Sep 20, 2015 01:44 AM
