Pulling power from drivers door?
Old Oct 26, 2007 | 08:56 PM
jimmbomb's Avatar
Default Pulling power from drivers door?
I want to pull 12 vt + - from the drivers door power window harness.
Now I get power from one of the Blue wires when the ignition is turn on, which is what I want.
BUT my test lead has to be grounded to the cars body to get it.. NOT to the door's body. There is no ground running thru the door sheetmetal.
SO. I figure that one (or more) of the wires in the harness must be a ground! ya think?? I mean how else would the circuits work without power & grounding..
So my question is... Which of the remaining wires are a ground (-) ?? I dont want to hook up a test lead for fear of blowing a c/beaker or fuze. Any help wouold be apreciated..
thanks.. .. jh
Old Oct 26, 2007 | 09:40 PM
xseveredveganx's Avatar
Utah Scions
If you're using an idiot light, hook 12+ to your aligator clip, then use the probe to find 12-. I've done it before on other cars and it's worked fine.
Otherwise just use a DMM.
Old Oct 26, 2007 | 10:18 PM
jimmbomb's Avatar
xseveredveganx.. you are a friggin' U-Genius!!! Good Answer.. I did just that & found it.. On the lower row... the Blue is the + & the white/black stripe is the - when ignition is ON.. Thanks a million. Now on with the project!.. jh
Old Oct 26, 2007 | 10:19 PM
Utah Scions
No problem!!
Glad I could help!!
Inazuma
20
May 3, 2023 01:58 AM
DaBlackBox
134
Apr 10, 2022 02:04 PM
Joeynenj
Nov 25, 2014 05:29 AM
