Under Dash LED spliced to dome light??? ANSWERED:)
Old Jul 5, 2009 | 04:59 PM
schpadoinkle's Avatar
Default Under Dash LED spliced to dome light??? ANSWERED:)
UPDATE: I got it working, lol, i forgot about the resistors being on the positive line ...all i did was tap onto the wires in the install guide for the door sills using t-taps and hooked up some leds from autozone ($9 for a four pack) and now i have under dash lights when you open the doors.
I'll post pics tomorrow
Original Post:
Ok... I've run out of patience trying to google around the web for info on this so here it is...
I wanted to get some small LEDs from Auto Zone, ect, and put them under my dash and have them come on automatically when I open a door (like sliced with the dome/door sill fuse). I'm have no idea how to use a multimeter and I've exhausted my resources looking for an "add-a-circuit" for the LOW-PRO Mini Fuses our box uses.
So, basically I'm wondering if anyone has done this yet or knows of any DIY out there that may be of some help.
P.S. if it helps i already have all the inteiror lights changed out to LED so the draw from that is already reduced...if that makes a difference...lol
Old Jul 5, 2009 | 10:03 PM
SanchezHacker's Avatar
Here's something that might help: http://trdsparks.com/install/00016-79810inst.pdf
It's the PDF installation guide for the illuminated door sills accessory, since the door sill lights come on when the doors open then that must mean they draw power from the same place you will want your LEDs to draw power from. I think the wire you want should be on page 8 of the PDF. Hope this helps some.
Old Jul 7, 2009 | 08:50 PM
Thanks Sanchez... I did look at this before but I'm not sure if i trust myself to start testing wires and stuff.... I looked around online and can't really find any other info tho.
Thanks tho, man
Old Jul 12, 2009 | 04:33 PM
ok, so i tapped into the wire for the door sills and hooked them up... its only around 8 volts on the multimeter (i have 12v leds) and the leds arn't lighting up but the door sills still are... anyone have any ideas where else i can get 12 low amp source from ?
thanks
Old Jul 12, 2009 | 04:57 PM
2ducks's Avatar
Is this what you want?
https://www.scionlife.com/forums/vie...ed+door+handle
thanks
Old Jul 20, 2009 | 01:45 AM
Pics...sorry for the non focusing-ness... my camera doesn't do well at night
Old Jul 30, 2009 | 02:42 AM
afterlifespecialist's Avatar
hey schpadoinkle i'm trying to do something very similar, but can't seem to get it to work, i'm trying to get an auto dimming mirror with map lights to hook up the same way but to no avail. I've followed the guide that sanchezhacker posted up as far as using a t tap to connect @ the #5 wire in the 6 pin connector but for the life of me it's not getting any power it seems. Do you have any pointers or have any install pics? any help would be appreciated.
horsefeathers
Sep 17, 2023 11:12 PM
XB06
May 30, 2015 02:42 AM
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
clickclickw00t
Feb 18, 2015 08:57 PM
TheTripleC
Jan 4, 2015 06:46 PM
