E-brake = rear end raises? Why?
I'm entirely clear that applying the hand brake after the vehicle has come to a complete stop does not cause the rear end to hike at all (emphasis on a complete stop). However, if the hand brake is applied and forward or rearward motion is attempted, then the rear has a tendency to hike, be it up or down, due to the brake application. That is simply a result of forgetting to release the hand brake. I think you missanalyze the situation.
Automatic I am assuming? Do this shift to neutral then apply ebrake then release foot brake and shift to park. This will also save tranny from slight strain over time
I always stop the car (foot still on service brake), shift to Neutral, set the parking brake, release pressure on the service brake, then shift to park. This allows the car to settle against the parking brake if you're on a slope, instead of all the weight resting on the transmission's parking pawl. If you've ever been on a slope without the parking brake set, you'll know that when you shift out of park, the transmission comes out of park with a *BANG*. Thats the transmission having to use lots of force to unlock the parking pawl because theres so much weight resting on it.
I'm going to pay more attention tomorrow and see if it still does it or if it's just me being in a rush
IMO, if you have a 5 spd manual (as I do, or an automatic for that matter) then if the vehicle is at a complete stop (no remaining momentum foreward or backward), and you apply the hand brake, then there will be no change in rear attitude. Any momentum in either direction will result in the vehicle "riding" up or down on the rear brakes (given hand brake application), and hence a change in rear attitude.
Ferretgrrl
Oct 15, 2018 02:50 AM
ScionVan
11
Dec 2, 2003 09:37 PM
. I'm on trd springs btw.
