Caliper went out
Old Jun 1, 2022 | 06:01 PM
Jaronson2020's Avatar
Default Caliper went out
I got a 2008 scion xb and my caliper needs replaced however if I do it on my own does the abs need bled or can I do it with brake bleed tool kit ? I know some cars have an abs system that you need a special scan tool to bleed the abs system.
Old Jun 1, 2022 | 06:22 PM
drizzoh's Avatar
Yes if you replace a caliper you will need to bleed that corner at minimum. You should not need to touch anything regarding the ABS modules themselves though. Probably would be a good time to do a brake fluid flush also if it's been more than 3 years since your last one. Can do it alone with some special tools but easier and more fun if you can find a friend to help whose done it before.
In short, just a standard simple brake caliper replacement. Scion's aren't fancy.
Tshock
Feb 21, 2014 05:25 PM
Glowbox
Apr 15, 2011 06:31 PM
johnhawkins
Dec 28, 2010 04:47 AM
Agent99
Feb 10, 2009 06:42 AM
mrlakers08
Scion tC 1G Wheel & Tire
Nov 5, 2007 09:15 PM
