Rear passenger brake popping noise
Old Jul 17, 2022 | 02:41 AM
Jaronson2020's Avatar
Default Rear passenger brake popping noise
So during changing my rear breaks I had a tough time putting new brake clips on due ti the previous owner using cheap breaks. So after using a little brake cleaner and elbow grease I was able to get the clips in place however my brake rotor was being scraped by the clip so I got a flathead and fixed it everything was fine and then a month later I started hearing a singular pop every time I brake from a low speed. I don’t hear it when braking on a highway or getting off the interstate only when I’m going 30 and under. It’s not multiple pops just one pop or clunk. It’s coming from the rear passenger. A friend of mine suggested I warped the rotor but I don’t experience any vibrations when braking.
Old Jul 17, 2022 | 10:46 AM
RichBinAZ's Avatar
If you brake going backwards, does it do just one pop? Then when going forward again, does it do the one pop again?
If so, it is likely the pads moving backwards/forwards in the caliper - could have something to do with the difficulty you had getting the anti rattle springs in.
Old Jul 17, 2022 | 02:55 PM
Sometimes in reverse it does it when pulling out of a parking spot but it’s not as often as if I’m driving under thirty and go to stop kr slow down
bjr
Dec 20, 2014 08:51 PM
martin1122
Apr 17, 2013 03:35 AM
Brakefade
Feb 26, 2007 12:22 AM
i007spectre
Scion tC 1G ICE & Interior
10
May 15, 2006 06:09 AM
sp0t
Apr 13, 2006 03:39 AM
