No emergency brake, pedal goes to the floor
How did you open up the rear caliper pistons when you replaced the pads? Did you unscrew the pistons or press them back? If you pressed them back most likely you have destroyed the pistons and will have to replace them. If you unscrewed them then check for possible leaks at the caliper or bolts that weren't put back. Hopefully it's as simple as the bleeder valve being left open.
toolz
10
03-24-2013 05:37 PM
xBino
03-17-2005 11:33 PM
sciontc_mich
09-06-2004 12:10 PM
