Tire size question
Originally Posted by flyer172
I would like to purchase 18x7.5 offset 42 rims, what is the widest tire I can go with without any modifications? Also what is the bolt pattern? Thanks.
Don't forget to use the search method--it can be your best friend and has saved me a lot of time not having to wait for an answer!
yea, I have found the bolt pattern many times over but still wondering about the widest size. Has anybody used a 235? Thanks.
I can't believe I'm posting this again; but I'm here to help:
I think the tire and wheel calculator we all use will help you understand how the changes from stock may or may not work, and what the resultant changes will be:
http://www.rims-n-tires.com/rt_specs.jsp?postId=906
Keep in mind that the stock tires are 205/55x16" with +45 offset.
Stock weight is approximately 22# for tire and 22# for steelie = about 44# total at each corner.
Have fun playing with the calculator/comparer!
FYI: 235/40-18 will give you about the same overall outside tire width and diameter as the TRD 19" wheels and tires.
BTW, do you plan on dropping it? How low you want to go can affect what tires can be accommodated, regardless of what is the biggest that will fit on any given rim width.
scionlife
371
Jun 2, 2015 11:00 PM
Besk_one
Oct 18, 2003 08:41 PM
