tire size question for 20s
Old Dec 28, 2007 | 03:49 PM
CPL_McMillan_USMC's Avatar
Default tire size question for 20s
So I'm getting a set of TiS Model 09...20x8.5 +38mm offset...i wanted to see if anyone here could tell me if a 245/35/R20 Nitto Invo tire would work with no rubbing...the specs are:
Nitto Invo 245/35/ZR20
Suggested Rim Size - 8.0 - 9.0"
Overall Diameter - 26.77"
Overall Width - 9.53"
the 245/30's diameter is 25.83"
i also looked up a 235/35 tire (seems to be what most people are running) NT555 nitto tire with the following dimensions...
Nitto NT555 235/35ZR20
Suggested Rim Size - 8.0 - 9.5"
Overall Diameter - 26.42"
Overall Width - 9.57"
am i wrong in thinking that the 245/35 tire should work just fine? i mean, the overall width is is a hair smaller than the 235s, diameter increase doesn't seem as though it would pose a problem , and the Suggested Rim Size is the same...
any input/advice??
Thanks in advance,
CPL McMillan
Old Dec 28, 2007 | 07:12 PM
avus's Avatar
sIcKsCiOnS
go with the 235s
no need to go as wide as 245 -- you're not driving a 4x4
and, most likely the 235s will weigh less than the 245s
weight savings, no matter how small, while riding on 20s is important
i have 235s on mine
Old Dec 28, 2007 | 07:22 PM
dannygenio's Avatar
I think you will need 235/30/20 not 35
Old Dec 28, 2007 | 10:26 PM
xseveredveganx's Avatar
Utah Scions
x2. That's what I'm planning on doing with mine. 235/30/20's for sure!
Old Dec 29, 2007 | 01:01 AM
avus's Avatar
sIcKsCiOnS
no, go with the 35series -- it will fit
i originally made the mistake of following TireRack's recommendation of a 30series tire -- and after 1 cracked wheel and 2 dented wheels, i went with the 35series for more sidewall cushion
it fit fine, and no more wheel damage from the 'great' chicago roads
Old Dec 29, 2007 | 02:58 PM
the reason i was asking if a 245/35 would fit is because the Nitto Invo isnt offered in a 235/35 or 235/30...
and though the tire may be wider than necessary, but functionality wise...would a 245/35 tire fit without rubbing issues?
or even, can you guys give me some tires to check out that are 235/35? i've searched a handful of websites and got about 2 results for that size...
thanks again,
Cpl McMillan
Old Jan 1, 2008 | 01:58 PM
Can anyone help me with this question? I'm buying my xB on Friday, and would like to buy the rims same day...
Thanks,
CPL McMillan
Old Jan 1, 2008 | 04:39 PM
Utah Scions
245 series will be too large. If you want to stick with Nitto, check out their NeoGen line. They have the smaller size's in a 20". Toyo also makes some great tires. I'm a fan of the Proxes4's from them.
Old Jan 2, 2008 | 08:36 PM
DiscountTireDirect's Avatar
The 245's will be a bit much, the Neogens are a great suggestion for an alternative.
Old Jan 2, 2008 | 08:46 PM
my_cubicle_part2's Avatar
go with 235/35.
245's? like Travis said "bit too much"
30's is not a smooth ride.
scionlife
371
Jun 2, 2015 11:00 PM
TravisXA
Aug 5, 2004 10:10 PM
1sikxb
27
Dec 20, 2003 09:33 PM
Besk_one
Oct 18, 2003 08:41 PM
BUzzBUcket
10
Oct 12, 2003 07:19 PM
