2009 Scion xD won't go into park
Old Nov 9, 2017 | 08:23 AM
plumbergirl's Avatar
Default 2009 Scion xD won't go into park
Has anyone else had a problem with their xD not going into park? Was there an easy fix or is this a transmission problem? The shift cable is fine, but when I try to turn the shift control on the transmission it goes into all gears but park.
I changed the transmission fluid and filter and there did appear to be some large chunks of metal, maybe the size of a bb. I'm able to drive it by cranking in neutral and using the parking/emergency brake. I have reverse adjusted up to park so I can get the key out.
Any suggestions on a fix?
Old Nov 11, 2017 | 01:33 PM
DAlex's Avatar
Oh, boy, do you have troubles! Large chunks of metal in the fluid are a very, very bad sign. Have you ever accidentally shoved it into park while moving? If yes, then you have ruined your parking pawl inside the transmission. Also, the chunks of metal floating inside have likely damaged other things. You need a rebuild.
Old Dec 15, 2022 | 11:33 PM
Christoph_XB's Avatar
What fixed your shifting problem? I have the same thing going on with my xB. Thanks
Lump
Dec 15, 2022 11:47 PM
turbohead
May 3, 2021 12:47 AM
seachels
Aug 6, 2014 01:51 AM
Jan06xB
Jun 6, 2013 02:38 AM
Spicy29
Jun 9, 2009 09:20 PM
