Scion xD ICE & Interior In-car entertainment and electronics...
Speaker/Door rattle because of bass?
Old Oct 28, 2008 | 08:26 PM
GeoUSA's Avatar
Default Speaker/Door rattle because of bass?
Anyone else have a problem with a severe door/speaker rattle when playing your stereo? My front passenger door buzzes mercilessly if there is even a small amount of bass. I have switched from my preferred equalizer setting to one with less bass, but the problem continues. The speaker is not blown and I don't listen at a ridiculous volume.
Just curious. I'm within 1,500 miles of my first free oil change and plan to ask the dealer to examine the problem. Thanks.
Old Oct 28, 2008 | 09:08 PM
A1binoA11igat0r's Avatar
I've noticed this as well. I wouuldn't call it Merciless but there's definately a vibration. maybe some sound deadening insulation in the doors would fix it?
Old Oct 29, 2008 | 12:13 AM
TrebleStauter's Avatar
I have tried to locate the vibrations and used insulated weather stripping to try to muffle or eliminate them.
I have not been successful.
I hope someone else has figured this out. I makes me crazy.
Old Oct 29, 2008 | 12:19 AM
mfo33's Avatar
for me it was the plastic weather guard, one solution is to take 'em off i guess...
Old Oct 29, 2008 | 04:07 AM
katchkillah's Avatar
well i didn't care for the bass in the sound of our speakers. LOL so i just turned down the bass all the way down so only get highs. but it still has some bass.
Old Nov 2, 2008 | 07:38 PM
arbnpx's Avatar
I was originally going to take off my door panels one weekend during this summer and hunt down the buzzing that I suspect is coming from the door panels. Unfortunately, I never got around to doing it.
Old Apr 6, 2009 | 11:01 PM
dzuv's Avatar
Default Re: Speaker/Door rattle because of bass?
I'm experiencing the same problem with my xD and was wondering if you discovered a solution for this.
Thank you
Old Apr 7, 2009 | 12:54 AM
SLODEANIS's Avatar
I had this. I had to take all of my door panels off, apply felt tape around the perimeter of each panel, apply foam tape to the door lock cables, felt tape around the power window switches, etc. The xD door panels just rattle and it will take some elbow grease to get it to stop. I can safely say I have zero rattles after all of the work I did. It may take 2-3 attempts of pulling the door panels off.
Old Jul 1, 2009 | 06:01 PM
yoaj's Avatar
just felt and foam tape did the trick?
i am suffering from severe door vibrations as well.
i have my amp to put in, but i havnt done so because i HATE the vibrations now and it will be absolutely horrendous aftyer an amp install.
can you post a pic of the door panel with the tape??
thanks much.
Old Jul 15, 2009 | 07:33 PM
GeoUSA's Avatar
Door would not rattle for dealership. It does come and go. Not happening now in warm weather so I'm guessing it's more of an issue when cold (parts shrink). Naturally it started again on my drive home from dealership. Rattle for me seems to originate mostly around the interior door lock/handle on the passenger side.
Old Aug 2, 2009 | 03:14 AM
formare's Avatar
Default Found the rattle
The door panel is in two pieces. if you put your hand into the cup holder and move it towards the rear of the car - push on the seem in that area and you will see that it is two pieces. I put foam tape between those tow pieces and have no rattle at all now.
Old Aug 2, 2009 | 03:34 AM
Sefi's Avatar
Will have to give that a try. I'm noticing an intermittant rattle/buzz to the music out of the passenger side door speaker area. At first I was wondering if I blew the speaker already but I hope its just the door.
Old Aug 13, 2009 | 12:23 AM
Tracompa3's Avatar
Not just me then...
This ticking noise (which is apparently in the door panel) drives me crazy. It doesn't occur every time there's bass, but every 10 seconds or so, there's a sharp "tick", that sends a sound into in my left ear.
I thought it could have been a defect in the left-front speaker, but I also hear it in silence while I hit a small bump on the left side of the car, or run over a reflector with the left wheel.
On a long drive with my wife, I told her about the noise, but she couldn't hear it from the passenger seat. I heard it every few seconds for about 5 minutes straight. Since it was a long drive in 5th gear, I put my arm on the pad on the door panel. Sure enough, there was no noise. When I ran over some reflectors to test it (with my arm on the padding, and again on the top of the door panel), the noise was gone!
Quite annoying, the only fault with the car so far. My guess is a loose clip/fastener in the door panel; perhaps there needs to be a felt strip of insulation around that area to quell the noise.
Edit: Fixed...scroll down ↓
Old Aug 16, 2009 | 03:36 PM
releaseme's Avatar
I have replaced the stock speakers and upgraded them. I also fully sound deadened the doors and the noise persists, I thought it was the crossover boxes rattling between the panel and the door, but I see many folks hear the noise. I'll try the wrapping of the cables and other things. I am able to make it stop as well by applying pressure to the panel just below the handle. Will keep ya posted as this is todays project!
Old Aug 18, 2009 | 07:55 PM
helixx's Avatar
Originally Posted by Tracompa3
Not just me then...
Wow, didn't think it possible, but I have the exact same ticking noise. It is rather annoying!
Old Aug 19, 2009 | 06:35 PM
WellesleyScion's Avatar
I had the same issue on my passenger front door, I pulled the interior panel off and broke a clip while I was at it.... turns out the clip wasn't installed right from the factory, without the clip there I have no rattle
Old Sep 3, 2009 | 11:22 AM
Tracompa3's Avatar
After two hours in the shop yesterday, the ticking noise was resolved! With a little adhesive felt around the door panel, and re-securing some clips, it all seems to have done the trick.
Kudos to Toyota, and meeting a service advisor I used to work with. The tech even let me test drive to confirm any other rattles (there weren't any).
Old Sep 8, 2009 | 05:21 PM
cbmikey's Avatar
I also have the bass rattle. Drives me nuts too. (Short drive, I know!)
I'll look into all these possible solutions. Thanks guys!
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
mxwes
Aug 30, 2015 09:11 PM
sethmskinner
Aug 4, 2015 02:38 AM
SFXB
Jul 9, 2015 11:00 PM
