2006 xB A/C problems
Old 06-30-2018, 08:20 PM
BlueToaster's Avatar
Default 2006 xB A/C problems
My AC will cool good sometimes then just quit. Then it will work fine, on and off.
I have replaced the compressor and still have the same problem. Something is failing intermittently.
Anybody found the fix for this problem?
BlueToaster is offline
Old 07-02-2018, 01:36 AM
GreggVA's Avatar
Not completely familiar with the xB systems but most have a high pressure and low pressure cut off that could be tripping and later resetting making it intermittent. If you just replaced the compressor and moved your other controls over, this might be the issue.
Assuming you have the proper charge in the system?
GreggVA is offline
Old 07-15-2018, 12:16 PM
Default A/C fixed
Thanks for the reply. I did find the problem. System was over charged. Lowered the pressure and it works fine now.
Jtrejo
05-14-2018 02:25 PM
tarponator777
07-13-2017 02:45 AM
billettesbox
03-02-2014 02:51 PM
jenkburke
07-28-2011 06:14 AM
lazermule
04-09-2010 12:31 AM
Quick Reply: 2006 xB A/C problems
