tC G2 Tech and DIY Info for the Scion tC G2
DIY Permanent, NON paper, door rattle fix.
Old Jan 20, 2012 | 01:20 AM
biglilsteve's Avatar
^Haha I love it!
Question though. I haven't gone to get the material yet, but I was wondering how many layers of it you need to use. Just one layer? That simple?
Old Jan 29, 2012 | 10:03 PM
Xander451's Avatar
Originally Posted by biglilsteve
^Haha I love it!
Just one layer, anymore and the panel won't snap back on.
Old Feb 2, 2012 | 06:57 AM
12stormtroopertc's Avatar
I used some of the Dynamat I purchased to do my doors. Did the same trick but today I noticed them rattling again. I must need to put some more, I dont think I put it in all the spots you mentioned though.
Old Feb 17, 2012 | 08:29 PM
BBesco2021's Avatar
xander great post but what made you go to the arts and craft section in walmart?
Old Feb 17, 2012 | 08:35 PM
Xander451's Avatar
Only place I could think of to find sheets of foam
Old Feb 18, 2012 | 05:52 AM
sneak's Avatar
Thanks for this, this rattling has annoyed me for almost a year! The foam stickers worked like a charm
I only did the driver side at the moment since it was really hard to get the cover on and off (messed up my fingernails). As far as I can tell the passenger side doesn't rattle but I'd like to do it on that side as well eventually. What's the best tool to pop the cover off without scratching anything?
Old Feb 18, 2012 | 02:51 PM
BBesco2021's Avatar
Originally Posted by sneak
(What's the best tool to pop the cover off without scratching anything?
Panel poppers. And if there is a Harbor Freight in your area they go for $10 or less.
Old Feb 19, 2012 | 04:37 AM
Sym_Link's Avatar
Thanks OP for the DIY. I used some industrial strength Velcro to stick an amp under my seat. So I had a bunch of the softer side of the Velcro left and it worked great for the door rattle. Just cut it and put it right where you said and rattle is completely gone.
Sent from my HTC Sensation Z710e using Tapatalk
Old Feb 26, 2012 | 11:58 PM
Andrew_Stevens's Avatar
Great mod/fix! Inexpensive and works perfect. Thanks for sharing.
Old Feb 27, 2012 | 01:39 AM
Druidiron's Avatar
It is more than likely your clips that hold the door panel on. I am now having the entire door panel rattle thanks to the clips being worn out from taking the panel off. At first, I thought I needed more foam, but if you listen close, it is not the window switch area; at least not in my case. I called the dealer to get replacement clips and they are $3 a piece.... we need either 9 or 11 (can't remember exactly) per-side.
I know that you can get aftermarket clips, but they usually are not as tight fitting as OEM, so it may not fix the problem.
Old Mar 7, 2012 | 10:11 PM
topher86's Avatar
Guess I am going to walmart tonight....
Old Mar 25, 2012 | 05:26 PM
topher86's Avatar
Great mod just finished
Old Mar 30, 2012 | 12:27 PM
jarvasdb1's Avatar
Default Sym_link
I have a bunch of velcro stuff. How is the velcro working out for you?
Old Apr 1, 2012 | 02:24 PM
jarvasdb1's Avatar
Well it turns out I was out of the soft side of the velcro so I went to Walmart and ended up getting these things called Super Sliders 3/8 in. in size. They are fuzzy pads with self adhesive side. I think I paid $2 for it and it came with 84 felt pads. They look like the stuff you put on cabinet doors so that when you close them they don't bang loud. They are located next to the Duct tape isle (assuming all Walmarts have the same lay out). I also used these on the slide in slots of the fog lights to make sure that it's secure. Hope this helps.
Old Apr 10, 2012 | 04:03 AM
Cement_11s's Avatar
Thanks! I finally got around to doing this and decided to use this!
I did the driver side just now and it works great and has no buzzing!! This seemed to be perfect and there was very minimal cutting! I also got it at Wal-Mart, but I've seen it for sure at Advance Auto Parts. I assume they would have it at AutoZone too.I found the foam he suggested, but like most of you have found way too much for a small project. I paid like $5 for it btw. Good luck!
Old May 6, 2012 | 03:40 AM
Rob2012TC's Avatar
Thanks for this post I just got done upgrading the stereo in my 2012 today and those switch panels in the doors randomly rattle, will fix it asap with your DIY post!
Old May 20, 2012 | 05:12 PM
Rob2012TC's Avatar
Are you supposed to heat it on electric stove burner prior to using it? : )
Old May 23, 2012 | 10:00 AM
Rob2012TC's Avatar
Done deal, picked up the foam at wally world, easy fix, works great. Now to get some dynomat and do the hatch/trunk/doors.
Old Aug 26, 2012 | 05:29 AM
husser94's Avatar
So happy with the outcome.. thanks! I thought i'd never hear the end of the rattling
Old Sep 19, 2012 | 10:28 PM
rsingh216's Avatar
Is it possible someone can rehost the pictures, they aren't working for me.
