tC Tech and DIY Info for the Scion tC
Dome Lighting Install
Old Sep 9, 2006 | 08:32 PM
  #241
JaN_MiChAeL_07's Avatar
heres minez .... all white LED's, Interior and License Plate
Old Sep 9, 2006 | 09:27 PM
  #242
babyfac3pn01's Avatar
thanks SquallLHeart
Old Sep 9, 2006 | 09:36 PM
  #243
Iride_xB04's Avatar
Its pretty simple, i put in green in my boxs overhead
Old Sep 12, 2006 | 07:12 PM
  #244
hawgs74's Avatar
Anyone know if these will fit in our Dome?
921-x12 Wedge Base LED bulb
921 Type with 12 LEDs, replaces 194/168/912 wedge base car bulbs
Wide 100 degree beam pattern, non-polarized
measures 1.20 inch long by 0.60 inch diameter
http://www.superbrightleds.com/cgi-b...6.2346&next=50
sorry if its been asked but dont have time to search 10 pgs of thread.
Old Sep 12, 2006 | 07:23 PM
  #245
R2D2's Avatar
Mod'n Bulbs = prerequisite to any car mod.
Old Sep 12, 2006 | 08:01 PM
  #246
imsonofagun's Avatar
I have the 9-LED 921 bulbs in my front dome right now. They work pretty good. They do stick out a little more, which puts them real close to the cover for the dome lights. As long as the 12-LED ones aren't much longer than the 9-LED ones, you'll be fine.
Old Sep 12, 2006 | 10:17 PM
  #247
im4degreesaboveu's Avatar
so i just did the dome swap to mine and have read this a few times and the general complaint is that it is sometimes hard to get the bulbs out. i used two pieces of duck tape and pulled them out with no resistance. since you will not be using the bulbs anymore why not, right. just thought that might help some of you out
Old Sep 22, 2006 | 05:28 AM
  #248
koolestkutta's Avatar
Do any of you ride with your interior lights on? If so, have you been pulled over?
Old Sep 24, 2006 | 04:46 AM
  #249
NADroj20's Avatar
does anyone know if the 9led will work instead of the 6 led in the front dome? and will the 9 led work in the license plate lights?
Old Sep 24, 2006 | 05:09 PM
  #250
DriveEuro's Avatar
Yes it will. I've used 9 led and 12 led in my front dome. Both work fine.
And the bulbs that have LEDs facing sideways are better for your license plate lights.
Old Sep 24, 2006 | 05:47 PM
  #251
NADroj20's Avatar
do u have a link for the sideways leds?
Old Sep 24, 2006 | 07:26 PM
  #252
DriveEuro's Avatar
http://www.superbrightleds.com/cgi-b....16718&next=50
9th one down. I have those in my license plate lights and they works great.
Old Sep 28, 2006 | 01:21 AM
  #253
crazycatholic's Avatar
just changed my LED's inside they look amazing! JUST DON'T TWIST THEM! i just spent like an hour trying to get them back after twisting and knockin them out!
Old Sep 28, 2006 | 06:45 AM
  #254
SquallLHeart's Avatar
hmm... it takes a few seconds to pull down on the whole assembly to get the part back out..
common mistake.. i think we're up towards the millionth one that's twisted it?
Old Sep 28, 2006 | 02:46 PM
  #255
haha i didn't take it out! i just hit the roof til they jumped back up there and i pulled them in!
Old Sep 28, 2006 | 05:39 PM
  #256
georgeo's Avatar
Default on on door
hey i just changed my back dome light to the blue led, but it lights up on the door position.it is not fully on but you could see it shining a little bit.
Old Sep 28, 2006 | 05:45 PM
  #257
try rotating it... mine did that and i just took the cover off and turned the bulb so that the LED's were facing down
Old Sep 28, 2006 | 07:22 PM
  #258
georgeo's Avatar
i tswisted then turn them but nothing still the same should i leave it like that or shoul i just turn it of .
Old Sep 28, 2006 | 08:50 PM
  #259
i dunno... did you try flippin it around? maybe it's in backward
Old Sep 28, 2006 | 10:28 PM
  #260
mdickson81's Avatar
I did mine last night, it was fine but I would ahve to agree try turning it around. Also are the points in the slotted holes? Maybe you are not getting enough juice.
