tC Tech and DIY Info for the Scion tC
Header Install (DC Sports)
Old Sep 14, 2007 | 09:18 PM
  #281
nrgwar's Avatar
thx for this INFO i have passed this on to many people that are installing the DC header for there first time also this works the same on most import cars BTY ;)
Old Sep 27, 2007 | 04:08 PM
  #282
XxTamTxX's Avatar
*bookmarking thread.
Old Oct 15, 2007 | 07:25 PM
  #283
jaybeme101's Avatar
your post was awsome, i just put the dc headers on this weekend and i had a few questions and concerns, you answerd em all, thanks...
Old Oct 15, 2007 | 10:04 PM
  #284
jaybeme101's Avatar
whats up bro, i just put in Anti-Foul's and the check engine light came off, BUT, my right door and sunroof are not working now, do you know what happen or what to do?
Old Oct 19, 2007 | 05:18 AM
  #285
amdforever's Avatar
yeah when you put the antifouler in you disconnected the battery...99%sure you did as most of us do. When you did that it disables auto up and down because the jam protector has to be enabled again. on the driver window button bring the window down half way and stop for a second. then push the button all the way down again and let the window go all the way down but continue to hold the button for about 2-5secs. 5 to be safe. Then pull the button all the way up and it should auto up. then go the passenger door and do the same exact thing, can not be done from the driver door button though. For the sunroof do the same thing. Open 1/2 way, then fully, hold button for few secs then release then push and hold til fully closed. Then push to and make sure it auto opens. All else fails, look it up in the manual but im pretty certain those are the steps, hope it helps ya.
Old Oct 22, 2007 | 03:14 AM
  #286
jaybeme101's Avatar
all windows are good, but the light is still on, i made sure all was tight and the light is still on thanks for all the info though it really was a huge help
Old Nov 3, 2007 | 01:46 AM
  #287
LordEvil's Avatar
Its been awhile since i have taken a car for emissions test, does headers mean failure ? Has anyone tried yet?
Old Jan 2, 2008 | 04:47 AM
  #288
highoffchlorine's Avatar
i tried and failed. tryin to figure out how to pass
Old Jan 2, 2008 | 07:26 AM
  #289
amdforever's Avatar
depends. If they just test the emission system and you have an antifouler trick or to some effect to throw off the O2 sensor then you'll be good. If they do a sniffer, then more than likely you wont pass.
Old Jan 7, 2008 | 03:27 PM
  #290
dsil06tc's Avatar
Default easy install
i installed the dc sports header with the help of my buddy and some air tools in about half hour-45 mins,really easy install and i was not expecting to have a raspy sound. the car sounds nice when it idles but when i step on the gas you can hear it.before with just my intake and exhaust my car sounded really good. now the scion sounds like a ricer!!!! I was told a resonator would solve the problem, wondering if anyone has had the same problem and does anyone know how to reset the check engine light the easiest way its really ____ing me off as well.
Old Jan 8, 2008 | 06:04 PM
  #291
bigwillystyle23's Avatar
as far as everybody disconnecting the negative battery cable, you dont have to do that.
opening your fuse box and removing the ECU fuse does the same exact thing, without resetting your windows and all that stuff. you also dont need any tools to do this, except for the HANDY DANDY FUSE PULLER stuck to the top of the fuse box lid.
Old Jan 20, 2008 | 06:21 AM
  #292
mengsta's Avatar
Damn those bolts on the exhaust bracket was hard to get out. Very stiff.
Old Feb 2, 2008 | 07:10 AM
  #293
nrgwar's Avatar
i just did my install & i have all the part to make the CEL not come on... also i installed the DC 4 int 1 & when i went 50miles my CEL came on WTF
so i think my next step will be to pull the (-) off & let the car sit for 10-20 mins then put the (-) back on & start the car.... Then i will let the tC idel for about 10-30 mins maybe this will fix the issues i am having... maybe the EUC needs to re map the new air flow going into the header & let it ideal might be the only way ;)
ill kep you all posted but for now chck out my install info
http://www.scikotics.com/forums/showthread.php?t=22972
Old Feb 2, 2008 | 12:21 PM
  #294
amdforever's Avatar
if your using the antifouler mod thats probably where your problem is. It doesnt always work for everyone.
Old Feb 2, 2008 | 09:39 PM
  #295
nrgwar's Avatar
yeah that could be the case also if i screw the o2 into the header it dose the same CEL after 25miles
Old Feb 2, 2008 | 11:35 PM
  #296
amdforever's Avatar
Um... the o2 is suppose to be in the header at all times. You put the antifouler trick on the rear o2 sensor on the s-pipe.
Old Feb 4, 2008 | 02:17 AM
  #297
nrgwar's Avatar
yes i know the o2 is on the false & still i got a CEL after a few miles WTF ?
Old Feb 4, 2008 | 03:27 AM
  #298
amdforever's Avatar
On the false? I assume antifouler. The antifouler mod is hit or miss, there is only one thing that I've found that has worked and I owned it and in 6+K miles never had a CEL https://www.scionlife.com/forums/vie...210&highlight= Dunno if he still makes them.
Old Feb 4, 2008 | 05:24 PM
  #299
nrgwar's Avatar
thx i sent them a PM so i hope they still make this i would love to lose that CEL i do nto have the spipe on the tC only the DC header
Old Apr 24, 2008 | 02:41 PM
  #300
lovetC's Avatar
thnx
