tC Tech and DIY Info for the Scion tC
Intake Install (Weapon R)
Old Apr 24, 2005 | 02:05 AM
mikek6789's Avatar
Wow! Great Post, For step 1.6, how do I unbolt that screw on the bottom?
Old Apr 27, 2005 | 02:49 AM
SoulOnFire's Avatar
Default Cool
Hey! Awesome instructions but i was wondering how much does this intake go for? im looking to getting into moding my tc but im not really into spending that much yet..
Old Apr 27, 2005 | 03:30 AM
toastbox's Avatar
Default Re: Cool
www.creativecompacts.com
James (the owner) has some great pricing
Old May 7, 2005 | 11:56 PM
tcchuck2005's Avatar
Default Cleaning out the intake pipe
I just got my kit. The intake pipe is full of metal shavings and crap. How do you get all the junk out of it before installing?
Old Jun 3, 2005 | 08:56 PM
cmwillis's Avatar
Mine too. I called and he said just to run water through it, and let it dry before installing. I havent installed mine yet, just took it out of the package to check it out.
Old Aug 2, 2005 | 07:45 AM
Smoses799's Avatar
You may also want to zip tie the evap system purge valve to some of the air hoses around it so it doesn’t move around, just don’t clamp off the hoses. Weapon R should have had a bracket for the evap system purge valve so it could mount to like the intake tube like stock. I’m going to look into making something for this a let you guys know how it goes.
How does having this hose hanging effect the car? What was this hose used for? Should i be concerned or worried about this not being connected? Will this cause me any problems?
sorry for the 1000x questions I bought the intake then read about this hose and was like "ohhh crap"
Old Aug 2, 2005 | 09:39 PM
Smoses799's Avatar
anyone?
Old Aug 3, 2005 | 01:23 AM
toastbox's Avatar
I'm not sure what you mean by "What was this hose used for? Should i be concerned or worried about this not being connected? " That hose *does* stay connected. It's actually two hoses. It connects to the evap system purge valve.
Old Aug 3, 2005 | 04:29 AM
Smoses799's Avatar
ahh i thought in that quote, he stated that there wasnt a connection for it
Old Aug 7, 2005 | 03:09 AM
Smoses799's Avatar
OMG !!! i just realized that in the kit CC sent me, I recieved 2x 2.5" to 3" adapters and no intake adapter !!!!!!
Old Aug 7, 2005 | 03:48 AM
Smoses799's Avatar
eeek, the long hose supplied with the kit seems like its 3x too long to fit from the stem on the intake tubing to lil hole that i removed the origional tube on the manifold from. Im 99% sure that my install is wrong. anyone have any more detailed pics or walkthroughs? or idiot proof guides
Old Aug 7, 2005 | 04:57 AM
Smoses799's Avatar
well i spiralled the hose, it seems to work. My car now sounds MUCH louder at idle and when accellerating. it seems to also have a slight whistle
Old Aug 7, 2005 | 07:06 AM
toastbox's Avatar
Yes, if you read the directions that came with the kit, it says to trim the hose with a razor blade. What I did was measure a few times, give myself some extra slack, like 4-5 inches, and cut. There was an obvious kink in the hose (planned), and I just continued to trim a little at a time, until I had it at the desired length, with no kink, and no excess slack.
Old Aug 7, 2005 | 07:11 AM
toastbox's Avatar
This is normal. All aftermarket intakes sound louder; this is due to the pipe being polished, instead of baffled, as well as the airfilter not being enclosed on a box. The whistle was actually always there on your car, but it too is also more pronounced with the polished pipe, non enclosed air filter.
Old Aug 7, 2005 | 07:12 AM
Smoses799's Avatar
you are my hero!!!
Old Aug 7, 2005 | 07:14 AM
toastbox's Avatar
Glad to be of help.
Old Aug 7, 2005 | 07:49 AM
Smoses799's Avatar
heh i think i might have cut too much off... getting sortof a kink in the hose now I am a idiot . I cut about 6 inches off I might be able to fix it with some adjusting
Old Aug 7, 2005 | 07:51 AM
toastbox's Avatar
yeah, thats why I recommend leaving extra, and slowly working your way down Hope you get it the way it needs to be
Old Sep 17, 2005 | 08:45 PM
TxtC112's Avatar
nice post makes everything step by step for us noob peeps
Old Jan 16, 2006 | 02:57 AM
rs1028tc's Avatar
I just bought the WR PIPE from someone, I ordered a KN filter online. Where can i get the rubber connectors (what size) and what about hose that will go from the pipe to the throtal body (size)?? Thanks guys PM's welcome
