tC Tech and DIY Info for the Scion tC
Intake Install (Weapon R)
Old Oct 1, 2009 | 05:23 AM
  #81
DJ08tC's Avatar
If you dont do it you wont be able to use the driver side switch to control the passenger window and the auto up and down wont work
Old Oct 1, 2009 | 03:52 PM
  #82
Vang2k's Avatar
when you install the intake you have to take off the negative plug on the battery. this results in your windows not being able to go back up once you press them down. this will happen with the moonroof too.
what you do is press both left and right windows down and hold it for like 10-15 secs. after that you press and hold them up for another 15 secs. repeat the same process for the moonroof. you should know when everything is working fine again.
Old Mar 17, 2010 | 02:20 PM
  #83
scion_040's Avatar
this might be a good diy to ask a question........ wut if i didnt disconnect the battery and install the intake? and another question, the brakets that comes with it... the one you bolt to the holes to make sure the intake stays in plaxe, what if i tighten them too much? will it show a check engine light? cuz my car was working great yesterday and today in the morning it started to show check engine light. does anyone knows why?
Old Mar 17, 2010 | 03:00 PM
  #84
asianorange's Avatar
I don't think your CEL has anything to do with overtightened brackets. The purpose of disconnecting the battery is to force the ECU to reset by removing it from power. Provided you're not too fast with the install, the ECU will be in its default mode when power is restored. Because the short ram (it's the same with cold air) changed the air intake dynamic, the ECU needs to relearn and you need to let your car idle for 5+ (or was it 15) minutes before doing any driving with the new intake.
Old Mar 17, 2010 | 03:08 PM
  #85
GQQSE13's Avatar
make sure yo pull the neg again for about 5 min and then re-connect and let run for about 5-10 min for ecu to relearn system and the cel will go away.
Old Mar 17, 2010 | 05:46 PM
  #86
scion_040's Avatar
thanks for i solved the problem.... i over tignted the
sri to the car.... i
loosen it up a lil bit and the cel
when off. dats weird..... i read that on 9thgencorolla.com but it was with the cosmo sri.
Old Mar 25, 2010 | 11:15 AM
  #87
seezatruth's Avatar
Okay, never done this before but...what is the rectangular box located just to the left, facing forward, of the air filter box and, I guess, it musn't be too important because it seems to get left off.
My question: I bought parts to create a cai. I am going to run it through the air filter box, and would like to run some big hose (like a dryer vent hose) down to the bumper and use that for the cold air...anyone done this and have pics of the set-up?
What to keep and what not to attach to the whole set-up is seriously kickin my tail here...
Old Feb 9, 2011 | 01:22 AM
  #88
Party_Box_Xb's Avatar
There needs to be more pic by pic with arrows intrustional threads like this. I"m looking for one on the Xb '05
Thanks for the thread. It's time to show my friend who has the tc.
Old Feb 8, 2012 | 04:58 AM
  #89
JepRocks's Avatar
does this apply on 2010? i dont know if there is a difference between Weapon R 2005-2006 and 2007-2010 ones.
Old Feb 8, 2012 | 05:22 PM
  #90
GQQSE13's Avatar
^^only difference on them is the maf sensor i believe
Old Feb 10, 2012 | 01:06 AM
  #91
mengsta's Avatar
Yeah install is the same for 2005-2010 TC. Just the 2007-2010 model has a different size Maf sensor so the two intakes have different part numbers.
Old May 30, 2012 | 09:37 PM
  #92
bB-aym-y0urs's Avatar
are the steps here applies to 2012 tC? or i cannot find a DIY for weapon-r for tC2. please help...
Old Jun 21, 2012 | 07:12 PM
  #93
GQQSE13's Avatar
i'm not familiar with the tc2 but i'm guessing it would be prety similar to this diy
Frustratez
Feb 26, 2015 04:03 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
Besk_one
21
Nov 24, 2003 04:30 PM
eric_m
29
Oct 12, 2003 08:22 AM
kidkamel
Oct 10, 2003 06:41 PM
