tC Tech and DIY Info for the Scion tC
LED Swap (05-06 HVAC w/Circuit MOD)
Old Dec 10, 2006 | 11:57 PM
  #261
engifineer's Avatar
Yep, you can melt it. Most of the time I just clip the blobs off with a pair of small wire cutters and it comes loose. I use either "Shoe Goo" if I have more time to let it dry, or testers model glue to put them back together. Super glue gel is also a decent way. It only takes a tiny amount.
Old Dec 11, 2006 | 01:03 AM
  #262
ADRdesignCo's Avatar
awesome thanks. and yes trung i know i could melt it.. but i was looking for something a little bit safer
Old Dec 11, 2006 | 02:51 AM
  #263
all4degame's Avatar
i used cuticle cutters from my sisters finger nail cutting set. They work really well
Old Dec 11, 2006 | 03:03 AM
  #264
mattieg's Avatar
Thanks Dave for everything!
Old Dec 11, 2006 | 04:58 AM
  #265
all4degame's Avatar
Originally Posted by engifineer
Looks good!
I take the needles completely apart when I do them. I remove the plastic lower peice and take the entire clear part out. This makes sure I dont hurt the center peice while cleaning and painting and also ensures I get it painted all the way back into the needle housing.
Super glue does work great to fix them if they break, but it is pretty nasty if you get it on the rest of it.
Dave,
I did take the needles apart. I was just careless when i was scrubbing the needle and broke the T that connects the needle to the hub. I reccomend everyone be very careful how hard you clean the needle.
Old Dec 15, 2006 | 11:38 PM
  #266
engifineer's Avatar
You can all look at the pics and see if you can tell what is different about this board (other than the LCD is not soldered in on the first two pics)
Write up to come after I drive it for a day or so :D Hint: It is just as bright as before.
Old Dec 15, 2006 | 11:44 PM
  #267
SquallLHeart's Avatar
I SEE differences!!!
haha... but then again... i know what to look for..
damn.. why didn't we figure this out sooner?
Old Dec 15, 2006 | 11:45 PM
  #268
engifineer's Avatar
^^ Yeah, your guesses dont count... you had inside knowledge
Old Dec 15, 2006 | 11:53 PM
  #269
i still kinda... knew what to look for though..
now only if you had clearer pictures of the "thingies".. so i know what to stock up on....
i'll just wait until the writeup i guess. :D
to the almighty dave!
Old Dec 15, 2006 | 11:55 PM
  #270
engifineer's Avatar
I'll include all part numbers. The pics came out a little fuzzy. Good camera, bad photographer
Old Dec 15, 2006 | 11:59 PM
  #271
i have a good camera too.... but i always have issues with lighting.. :?
Old Dec 16, 2006 | 12:04 AM
  #272
ITS PHOTOSHOPPED! lol. jp
it looks alot cleaner but im still kinda stumped, have an idea, but still no where to be found. lol good job
Old Dec 16, 2006 | 12:05 AM
  #273
engifineer's Avatar
Thats my deal. I have an SD630 (Cannon). In the area I do the mods in, It is tough to get the lighting right for the picture. Shutter is either open too long, making it blurry, or not on long enough. But, probably because I am too lazy to set it manually. I have the same issue with most cameras when I dont take my time.
Old Dec 16, 2006 | 01:22 AM
  #274
engifineer's Avatar
Ok, for everyone else, I'll stop being mean It is a modded HVAC board. No wires, no resistors added, no cutting of traces. Just a matter of knowing what to replace elsewhere on the board. I originally thought of this idea during my original mod, but due to not having the entire board mapped out, and some preliminary testing thought it would fool with the processing for the rest of the board. I did a LOT more mapping and testing on the board recently and found that it would work... so it is now done and installed on mine. A little more testing tomorrow and driving the car and I will call it good. Then create a new write up with all the new part values and instructions.
Old Dec 16, 2006 | 01:34 AM
  #275
aznpimp's Avatar
awesome .. please hurry lol jk I will give this a shot tho have no clue about electrical stuff
Old Dec 16, 2006 | 02:10 AM
  #276
Jdogg440's Avatar
Awesome, squal was just telling me you had an easier solution,. I just ordered all my leds, so i'll be watching, and waiting for the writeup, then its on. thanks guys for all the hard work it must take to figure this ____ out.
Old Dec 18, 2006 | 02:53 AM
  #277
engifineer's Avatar
Ok all... the fix works. I tried to start the new write up, but I had a set of gauges, HVAC, window and steering wheel controls, plus the LCD reversal on the odo (that adhesive takes a while to remove ) today, a school project to help my son with and I have the flu... joy :D
So I didnt get it done. I have have pics taken and part numbers, I will just have to write it all up tomorrow. Sorry everyone!
Old Dec 18, 2006 | 02:57 AM
  #278
hope you get better! the flu sucks!
Old Dec 18, 2006 | 03:45 AM
  #279
all4degame's Avatar
Just as I got your old kit in, you came up with a new solution Dave! Hahaha Good work.
Old Dec 18, 2006 | 01:50 PM
  #280
engifineer's Avatar
Yeah, I was thinking of that Have you installed it yet? If not I would be happy to send you the parts for the new kit to use instead. Both kits work equally well, the new one is just easier and cleaner to install since it uses the existing board locations.
Basically, there is one IC and 7 surface mount leds to swap out. I will get the info on part numbers and location up tonight. I did an 07 over the weekend, so I will have info on both HVAC's in the same write up.
