tC Tech and DIY Info for the Scion tC
LED Swap (Steering Wheel Controls)
Old Mar 8, 2008 | 05:07 AM
  #81
SicktC06's Avatar
Is it normal for these LEDs to be much harder than the others? It seems they are glued in the middle... is there a trick for getting these off? I remove most the solder I can from the pad but I still ended up breaking off a pad the LED goes on when I tried ot get one side of it up... It's like there is a glue and i am stumped. Now I gotta go buy a new Steering wheel control. =/ Any suggestions on easier removal?
Old Mar 8, 2008 | 08:06 AM
  #82
SquallLHeart's Avatar
yah, there's some glue thingy in the middle of each led..
haven't had much issues removing them... just use enough solder on there to melt it, and i actually go back and forth getting both sides melted before i apply enough pressure to break that gluey crap.
or i just use hot tweezers.
Old May 28, 2008 | 04:01 AM
  #83
1_kLEan_tC's Avatar
Someone should stick this!
Old Feb 23, 2009 | 11:21 PM
  #84
CanxB's Avatar
Originally Posted by FromThisSoil
Originally Posted by IAmTheProdigy
Probably a ridiculous question, but when removing center section of the steering wheel, are there any precautions in regards to the airbag? I think not, but I just want to verify. Thanks.
Always disconnect the negative battery cable when working with onboard electronics, especially around airbags...
The thread I read on the steering wheel swap for tC to a xB say to disconnect the battery and wait for 15 minutes to let the ar bag discharge and it also said if you are going to place it down, put it face side up.
Good luck, I will be doing this one in the near future to BLUE.
Old Jul 22, 2009 | 03:45 PM
  #85
EastTNScionxB's Avatar
DeepSouth Scions
Originally Posted by jetlounge
ugh...3 leds! i only have 2 left over from my console/gauge change. and lcled has a 30 led minimum.
oh rats!
HAHAHA! ME TOO!! Dang it!!!!
Old Oct 5, 2010 | 01:50 AM
  #86
charlie07tc's Avatar
i took this piece off to paint it and theese 4 white thingies fell out of the buttons, does anyone have a pic of how the are supposed to look on the inside of the buttons?
Old Oct 5, 2010 | 01:52 AM
  #87
j3st3r's Avatar
Music City Scions
They should only go in one way(they should have a flat spot on one side), those are what push against the membrane and make the contact with the circuit board to activate the various functions
Old Oct 5, 2010 | 02:50 AM
  #88
pics would be helpful if anyone has some, they aren't as easy to align as u might think.
Old Oct 6, 2010 | 12:13 AM
  #89
you know those toddler toys where you push the correct shape thru the correct hole?
same concept.
Old Aug 6, 2011 | 05:18 AM
  #90
MaverickBalla41's Avatar
Default Do i need a resistor?
I currently have the stock amber steering wheel control lights. If i exchange them for blue LEDs do i need a resistor too? If I do how do I get an extra for my steering wheel?
Old Sep 18, 2011 | 01:51 AM
  #91
torranosaurus's Avatar
My 2012 tc 7.0 has the wheel controls, but they don't light up!(?) Sucks at night.
Old Sep 18, 2011 | 08:27 AM
  #92
nope.. they don't light up.
Old Sep 23, 2011 | 01:45 AM
  #93
All my other Scions light up, makes no sense.
evolving_machine
Oct 21, 2023 01:16 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
toyotaisme
Jan 10, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
