Pulley Install (NST, Underdrive Crank, Water Pump, Alternator)
#161
Originally Posted by Trivecta
bump....I'm thinking about this but is it worth the supposed "risks"
As for worth it... ya. For the feeling and potential power - they're a great bolt on that you can actually notice.
#162
well, I read threads a few months ago about harmonic dampening and what not....and so thats been keeping me away from this for a while. I'm currently torn between getting a ETD, pulleys or an intake.....
#163
You'll notice more from the pulleys, IMO (though I do not have an ETD).
Best post to read on the harmonic dampening...
https://www.scionlife.com/forums/vie...281720#1281720
#164
Has anybody installed these 3 with the S/C already installed? I'm going to tackle it soon and I wanted to see if anybody had some advice for me lol....now the only problem I'm having is, finding a new belt that will work with the stock s/c pulley and the smaller alt pulley, any suggestions? thank you.
#166
The most COMPREHENSIVE thread regarding pulleys, all the most frequently asked (as well as hardly ever asked) questions and answers, pictures, customer reviews, and anything else you would ever want to know about NonStopTuning Crank, Alternator, and Water Pump Pulley Kits can be found here...
https://www.scionlife.com/forums/sho...d.php?t=154930
Good luck and have fun with all your projects everyone!!!
#168
was gonna install my underdrive crank pulley today, but i had to run to advance for a serpentine belt tool. that tensioner is ____ing impossible to get to! there simply isn't enough space to fitch a ratchet and socket between the side of the engine and the metal framing the engine bay. now that i have the serpentine tool it's too dark to work. sheesh. ill try again tommorow and it should go real quick. ill post with my thoughts.
#169
Thanks.... sorry I let some of the pics get out of sync on my hosting server... fixed now, but lost one pic... (it is a really old post though and I've moved away from Scions, but I'll keep the pics up as I think it's one of my better DIYs)
#170
Thank you very much. This is a great DIY guide indeed
#171
I just installed my NST pulley set today - and I can definitely feel a difference. First and second gear go by alot quicker. I just thought that I would share a trick that my friend used to get the crank pulley bolt off - for those that don't have an impact wrench. Just grab a sturdy socket wrench with the 19mm socket on it and put in on the bolt. Position the wrench so that the handle is in front of the lower control arm (to the right of it if you are looking at the pulley). This is what will keep the wrench from turning. After the wrench is set, put the keys in the ignition and turn the key so that the starter will try to turn the engine over. It only takes one click of the starter - be careful to not start your car. Since the crank pulley turns clockwise, it will break the bolt loose. I was absolutely amazed at how easy this was - and I couldn't beleive that I had not read this anywhere. Anyways, I love the pulleys - thumbs up for NST. Time to begin the turbo fund...
This tip how ever old it is, is absolutely priceless. I was struggling trying to hold the crank pulley in place and then decided to give it a whirl. THANK YOU! haha
#172
Installed Crank, Alternator, and water pump pulley....LOVE IT! More torque and better throttle response.
Installation was easier with air tools, but overall, it wasn't bad. about 3 hours. I decided to remove the alternator entirely. Makes everything so much easier.
I drive an 05 Automatic with 128,000 miles. No problems so far! Thanks NST!
#173
THANK YOU!!!
And thank you everyone, who has chimed in here in this thread. Your help and support is always much appreciated!
#175
NOVEMBER 2013 GROUP BUY!!!
Please visit this link for all the info...
https://www.scionlife.com/forums/sho...&postcount=434
Thank you guys, we appreciate the support
MIKE @ NST
MIKE @ NST
DaBlackBox
134
04-10-2022 02:04 PM
NonStopTuning
01-20-2015 05:20 AM
TheTripleC
01-04-2015 06:46 PM
TheRedBox
31
12-02-2003 04:53 PM
