tC Tech and DIY Info for the Scion tC
Racing Seat Install (Corbeau A4)
Old Mar 29, 2008 | 05:36 AM
  #61
Big_hungry's Avatar
I have a few questions.
were going to tackle putting seats in a tc soon.
these are stupid questions but I want to make sure we have everything covered. I don't want to be in the middle of doing the install and have to run to the hardware store lol
so what have you guys used to space the seats up?
Did you have to get a longer bolt when you spaced them up?
Also was it hard to attach the bracket to the sea?
I installed two different sets of corbeau's in my old wrx years back and the brackets were a pain in the **** to get on to the seat .
I'm guessing after 5 years they have had time to fix this problem hopefully.
Old Mar 29, 2008 | 02:04 PM
  #62
Elijahtc's Avatar
Bump
Old Mar 29, 2008 | 11:16 PM
  #63
Nick06tC's Avatar
I bought washers to space mine up and still havent done it I need to tho. Wife wants the passenger side done bad!!
I think the bolt will be long enough.
Attaching the bracket is cake, for the brands I used. ZERO issues at all. Only slight issue is those allen bolts dont want to stay tight. Every few months, I have to tighten 2 of the bolts. Loc Tite would be good!!.
Install is pretty darn easy!!
Old Mar 30, 2008 | 02:21 PM
  #64
Elijahtc's Avatar
thanks Nick. When spacing it up how big of a spacer should i get for front and back? Wouldn't the front need to be just a tad bit higher than the back?
And since i'm gonna be running a quick release setup should I even worry bout connecting the air bag sensor?
Old May 20, 2008 | 07:36 PM
  #65
yellowxhoodie's Avatar
big bump.
but i need to remeber this thread. lol
Old May 7, 2009 | 08:05 AM
  #66
tc-guy's Avatar
need to remember this thread for when the time comes. thanks.
Old Jul 5, 2009 | 12:31 AM
  #67
ack154's Avatar
Added to Tech... since somehow this was never added before.
Old Jul 20, 2009 | 03:32 PM
  #68
HKSpeed's Avatar
watching
Old Aug 14, 2009 | 08:02 PM
  #69
jazar07tc's Avatar
nice write up and the seats look great. do you actually drive with the seats reclined that far back? LOL. seems a bit dangerous.
Old Aug 14, 2009 | 08:40 PM
  #70
Mos_Def's Avatar
nice
Old Dec 10, 2009 | 01:28 AM
  #71
GQQSE13's Avatar
bump to use this weekend (finally!) how big of spacers did you use?
Old Aug 25, 2010 | 04:10 AM
  #72
djbildo's Avatar
how much lower does this sit you in the car?? cause i would loveeee to be sitting lower.. im 6'3" and love my tc but this car is too small for me, my head is always rubbing and hitting the ceiling and gets uncomfortable and annoying ... if these racing seats add some style, as well as lower me down, i am very very interested... please reply!! thanks =)
Old Aug 25, 2010 | 11:52 AM
  #73
ack154's Avatar
I don't have any exact measurements, but I would guess at least an inch lower... When I autox with stock seats, my helmet hits the edge of the sunroof opening a tiny bit and it get a bit annoying. When I had the CR1s installed I didn't have that problem.
And I'm 6'3", about 215 lbs.
Old Aug 25, 2010 | 01:23 PM
  #74
GQQSE13's Avatar
yea i think mines about 2" lower and definately made a noticeable difference because im 6'3 as well and i have more headroom than i did with stock seats.
Old Dec 2, 2012 | 06:21 PM
  #75
pdool09's Avatar
Originally Posted by TCpete
just some FYI .... i have a fix the SRS light (airbag) when you do this install... all you need to do is basically take off the black box on the driver seat were the harness connects onto ... once you take it off and clip is back into the harness just slide it onto the bracket and it will stick to the bracket because the actual box is magnetized!!!!!.... that bolt for is a major PITA!! so grind it down.. the use a dremel and cut a slit onto the bolt... then use a flat head bit connected to a sock wrench or flat head screw driver, slide the flat head into the slit you just cut with your dremel and vuala.. just loosen it off and ur done....connect it to the harness..mount it or leave it under the seat and no more AIR BAG light.. woot! ...no money spent on resistors and your using oem parts...
I`m going to give this a try right now and see if it solves my Airbag light issue. The current resistor fix posted in the DIY section doesn`t match what my 05 TC has for connectors under the seat.
Thanks for posting TcPete!
Old Dec 2, 2012 | 07:37 PM
  #76
pdool09's Avatar
Thumbs up
Success! I SCAVENGED the harness and the little black magnetic module from the OEM seat and no more srs light. Now I can get the car inspected. LOL
Thanks TcPete for pointing out the easy way to solve this in an 05 tc.
NonStopTuning
Jun 29, 2015 07:42 PM
Frustratez
Feb 26, 2015 04:03 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
Risen_Son_Racing
May 6, 2005 02:31 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
