tC Tech and DIY Info for the Scion tC
Transmission Flush (Manual, Redline MT-90)
Old Mar 19, 2008 | 05:56 PM
  #241
Olorin9's Avatar
any help for those of us with auto?
Old Mar 19, 2008 | 06:31 PM
  #242
InfideL's Avatar
just so you know auto doesnt use the same fluid
Old May 19, 2008 | 04:58 AM
  #243
GammaTNT's Avatar
how long do the mt-90 last?
My car have 35k miles since last change.
It is time to change again?
Old May 21, 2008 | 07:29 AM
  #244
supraman21's Avatar
I made a switch from Royal Purple to Redline MT90. I do not feel a significant difference. Shifting through the gears feel the same.
Old May 26, 2008 | 07:10 PM
  #245
KINGxOFxSKA's Avatar
Unique Scionikz
https://www.scionlife.com/forums/vie....php?p=3474844
Old Jun 15, 2008 | 03:36 AM
  #246
Edmond's Avatar
I ordered some Amsoil GL-4 75w-90 for the gearbox. I'm hoping to get it swapped in the middle of the week.
I only have 1700 miles on the car but I'm switching it out hoping it'll shift smoother. I've grinded the gears a couple of times from not paying attention.
I also ordered some Amsoil 0w-20 100% synthetic motor oil and a Amsoil oil filter.
I figured that since I'm a dealer, I should use the product on my Scion like I did for my previous car and parents' cars. I'll probably end up doing twice a year oil changes. I'm figuring to average about 11,000 miles a year. The Chicago summers and winters can be pretty bad.
Old Jun 18, 2008 | 02:37 AM
  #247
Edmond's Avatar
Guys,
Where can I find 6 point sockets in 27 and 24 mm at?
Old Jun 19, 2008 | 06:59 AM
  #248
Coolwaterz's Avatar
its ok to fill the tranny until it drips out of the fill plug?
Old Jun 19, 2008 | 11:28 AM
  #249
SquallLHeart's Avatar
yes... it's supposed to be at the level to where the fill plug is
2.6 qts. no more, no less.
Old Jun 23, 2008 | 04:55 AM
  #250
supraman21's Avatar
I dont think you want to go with a socket, a wrench is better. I used a 15/16, it was close enough.
Old Jun 23, 2008 | 05:08 AM
  #251
Coolwaterz's Avatar
double wrench ftw
Old Jun 23, 2008 | 05:17 AM
  #252
CSOCSO's Avatar
there is any diy how to bleed the clutch?
Old Jun 23, 2008 | 08:08 PM
  #253
Drey's Avatar
I change mine last Friday. Redline MT-90. Can't really tell difference. Well its seems to be easier to put car in reverse now maybe its just me.
Old Jul 2, 2008 | 04:15 AM
  #254
Edmond's Avatar
I just changed my fluid today. Took just a drip over 3 quarts of GL-4.
Finished in less than 30 minutes.
On my '08, both the fill and drain plugs were 24mm. Getting to the drain plug with a socket is just about impossible but it's the perfect job for a box end. But I didn't have a box end 24 so I borrowed a neighbors. Unfortunately, it was a 12 point but it worked, would've preferred 6 point.
Another bad thing is that I couldn't get a torque wrench to the drain plug.
I'll figure something out for the next time.
The factory fluid was still pretty bright, almost a waste to change it out but I'm a believer in synthetics. I used Amsoil GL-4.
I also switched the oil over to 100% Amsoil synthetic.
Can't notice an difference, probably won't until I drive the car when it's cold.
Old Jul 2, 2008 | 04:58 AM
  #255
airswipes's Avatar
i havent checked yet..but doesnt the s/c cover up the tranny fill hole? just thought i'd ask since i'm already on here
Old Jul 2, 2008 | 05:02 AM
  #256
Ace83's Avatar
Ronin Scion
oh damn i've been looking for this, thanks for the bump
Old Jul 2, 2008 | 07:25 PM
  #257
Diluvium's Avatar
Hey instigator i think you left out one more instruction at the end....
After you install your new transmission fluid in and tighten everything back up, your suppose to shift into each gear letting the fluid sink in to each gear before your drive your car or maybe turn on your car.
its the proper way to pre-sync? not sure wats the actual term for it, but its for safer and proper way in general, said by a master mechanic.
Old Jul 2, 2008 | 08:17 PM
  #258
Coolwaterz's Avatar
omg the 1 and 1/16 socket is so dam hard to find...
kragen has them but they didnt have the 10" extension... for a 1/2 drive... wtf
Old Jul 2, 2008 | 08:24 PM
  #259
tc-guy's Avatar
instead of filling it through the back-up sensor, couldn't u just fill it through the tranny fluid dipstick tube? i've always filled up my other cars tranny fluid through there. i could be wrong but it would be easier if u could fill it up through there.
Old Jul 3, 2008 | 07:01 PM
  #260
g2autosports's Avatar
Great DIY, I have 105K on my tC and its time to change it again, starting to feel like the gears are not going in smoothly anymore, this will be the second time its being done, I used Royal Purple the first time and I was very happy with the results, so I think I will use it again. Oh...and I have a manual trans. with the original clutch, which is still working well.
