tC Tech and DIY Info for the Scion tC
Transmission Flush (Manual, Redline MT-90)
Old Jul 3, 2008 | 10:25 PM
  #261
Coolwaterz's Avatar
hey guys is the socket from the drain plug for the transmission oil 21mm? are they bot 21mm?
Originally Posted by tc-guy
instead of filling it through the back-up sensor, couldn't u just fill it through the tranny fluid dipstick tube? i've always filled up my other cars tranny fluid through there. i could be wrong but it would be easier if u could fill it up through there.
dont think manuals has dipsticks but autos do.
Old Jul 4, 2008 | 01:56 AM
  #262
tc-guy's Avatar
ahh that would explain it then.
Old Jul 6, 2008 | 12:55 AM
  #263
d0ugch0i's Avatar
nice write up
Old Jul 6, 2008 | 02:30 AM
  #264
Coolwaterz's Avatar
is the drain and add plug 24mm?
cuz the 7/8" doesnt fit...
i'll try 15/16" or 24mm and use which ever fits better.
man is problem is holding up the change...
thanks for not posting wat the size is...=/
Old Jul 6, 2008 | 04:10 AM
  #265
tCeeder's Avatar
it should be 24mm for the drain plug and 1 and 1/16th for the reverse sensor..... try looking back a few pages next time.
Old Jul 6, 2008 | 04:57 AM
  #266
dasiknes803's Avatar
Good stuff man.
Old Jul 6, 2008 | 07:57 AM
  #267
Coolwaterz's Avatar
alright finally did it. the whole thing took less then 30mins. i would have finished it in less then 15 but i took it slow and waited for the dripping to stop. dam that stuff is thick...
i borrowed my friends snap-on tools (they rock!!) a 15/16" will work just make sure you use the circle side not the Y side.
cant 8 to drive it 2morrow. hopefully i'll feel a difference.
anyone know how to disposed the transmission oil? what place takes them?
Old Jul 6, 2008 | 02:17 PM
  #268
ElevationTC's Avatar
good write up! Hopefully it works out better for everyone else then it did me!
Since ive switched to this fluid, ive noticed 3rd gear grinds!
Never ever ever ever had this happen before!
Switched back over to factory fluid and it went away?
Dealer said they had someone else with the same problem, that the best fluid is oem!
Old Jul 6, 2008 | 02:55 PM
  #269
tCeeder's Avatar
i couldnt tell the difference after switching from oem to the Redline stuff. i changed mine at 30k and i'm going on 38k now.
Old Jul 6, 2008 | 03:10 PM
  #270
faux_ghost's Avatar
i will have to switch mine out when i get a chance
Old Jul 7, 2008 | 06:29 AM
  #271
Coolwaterz's Avatar
i switched to mobil 1 tran fluid and the shifter feels "creamy"
worst thing that happened was 2nd gear didn't catch and it grinned a little onces.
shift slow for the first few miles.
Old Jul 10, 2008 | 07:04 PM
  #272
Diluvium's Avatar
WOOT just got it done an hour ago. probably only take 30-45min, not include finding the right tools.... but the all the bolts came out real easy. Just have a 27mm w/extension (remove sensor) and 24mm (drainer/filler) your good to go.
changed it at 86k miles with Redline MT-90; shifting is more slick, shifting is more quiet while driving, and overall feels brand new again.
Old Aug 3, 2008 | 05:51 PM
  #273
ack154's Avatar
Just finally did this today. Had bought all of the random tools ahead of time and it took me 15-20 min. Cake.
Went with Redline MT90. No incredible difference yet... but that old fluid was NASTY. But I guess 62k miles will do that to a transmission.
Old Aug 3, 2008 | 09:31 PM
  #274
Ace83's Avatar
Ronin Scion
^^ and that oem fluid is like water, mine got changed at 37K.. What I noticed is that I dont hear that klank klank sound when I shift especially reverse or 1st
Old Aug 4, 2008 | 07:15 AM
  #275
TylerC08's Avatar
Hmm, very relieving hearing someone else talk about the clunk/clank when shifting. I asked the dealer about my clanking noise while shifting and they ended up changing the trans fluid around 5,500 miles. They said it was practically black and couldn't figure the cause of it. I'm probably going to try MT-90 once I get my next oil change.
Old Aug 4, 2008 | 08:31 AM
  #276
CDogbert's Avatar
Same all around. I just changed mine to MT-90 at 55k; old stuff was garbage, and I haven't really noticed much of a difference yet.
Old Sep 26, 2008 | 10:52 AM
  #277
JL514's Avatar
the reverse sensor happens to be under a large chunk of metal since I have a supercharger. How hard is it to fill from the fill port underneath the car?
Old Sep 26, 2008 | 04:46 PM
  #278
SquallLHeart's Avatar
imo.. pretty easy as long as you have the right tools.
either a really nice long funnel with a tube to fill from the top... or a pump with a tube that goes up from underneath
Old Oct 3, 2008 | 06:53 AM
  #279
CSOCSO's Avatar
okay just make sure i understood the DIY write up
so i open the hood, take off the reverse sensor ( on top of the trans) and put it back by hand, not tightening it up with any tool.
below the car i remove the plug showed in green circle after the oil is drained i put it back, tighten it
then unscrew the plug showed in red circle, go back to the reverse sensor start filling it up with the oil and when i see the oil coming out on the bottom i just screw that bottom plug back really fast, while the oil will puring on my hand?, then plug the reverse sensor back.
how do i bleed the clutch?
Old Oct 3, 2008 | 11:34 AM
  #280
BAMF4Life's Avatar
when you say 3 full bottle.... (quarts)?
