tC Tech and DIY Info for the Scion tC
Transmission Flush (Manual, Redline MT-90)
Old Oct 21, 2008 | 12:13 AM
  #301
sp2's Avatar
sp2
Defined3
great right up
Old Jan 14, 2009 | 02:36 AM
  #302
dnaval4684's Avatar
hey guys,
newbie to working on his car. i was trying to remove the drain plug to the transmission but i'm stuck. my socket wrench wont fit in that tight spot. my adjustable wrench wont catch on the bolt. i need some help and advice if anyone has any. i know it may sound stupid but im trying to learn. thanks everyone.
Old Jan 14, 2009 | 03:39 AM
  #303
web's Avatar
web
All the way to the right you will see the 24mm socket you need. It's a shallow socket and you may need to get a pivot-head breaker bar as in my other picture below:
It's a very tight squeeze with these as well but once you crack it free, just slide the socket/bar off and use your finter to loosen the bolt.
DO NOT JUST TAKE THE BOLT OFF QUICK!!! OIL WILL GO EVERYWHERE.
Hold the bolt over the hole and allow the fluid to drain slowly and in a controlled manner.
Old Jan 14, 2009 | 02:24 PM
  #304
ValenciaS's Avatar
hey guys dont know if this has been asked i have 5,XXX miles on my 5speed 09 , should i make the switch to sythetic MT90 ? also how often do you have to change the trans fluid ?
Old Jan 14, 2009 | 10:31 PM
  #305
web's Avatar
web
^It wouldn't hurt and your gear box would benefit from the synthetic switch early for the long run.
I do mine every 30K on the dot, no later.
Old Jan 15, 2009 | 04:09 PM
  #306
ValenciaS's Avatar
with the 2009 tc takes MT90 ??
Old Jan 16, 2009 | 09:57 AM
  #307
web's Avatar
web
Yes, same transmission and gear box.
Old Feb 23, 2009 | 12:41 AM
  #308
jamarr911's Avatar
Hey I just did this but with Amsoil 75-90. For all of you who did this switch with both Amsoil and Redline MT-90, when did you feel the difference in the smoothness of the shifting? Was it immediately after changing the fluid, or was it as you drove the car around for a while?
Old Feb 23, 2009 | 12:47 AM
  #309
web's Avatar
web
Mine was after a few miles of driving around and shifting a lot. I would say that after about 10-15 miles I began to notice the shifter sliding a bit smoother. Basically, wait until the fluid is allowed to "touch" all of the gear box internals and then the shifting will become a bit smoother. Take the car up hills and over bumps so that the fluid can slosh around a bit in the gear box.
Old Feb 23, 2009 | 02:23 AM
  #310
jamarr911's Avatar
ok thanks because I took it around the block, (no where near close to even 1 mile) and I didnt notice any difference. I even went through all the gears before I turned the car on after the fluid was changed. I drive 280 miles/day so I guess ill definitely notice it tomorrow...
Old Feb 25, 2009 | 02:19 PM
  #311
Autodromo's Avatar
I have tried MT-90 and Motul Gear 300, and I don't think there is any difference in shifting smoothness between stock oil and synthetic oil. The only thing I could notice was with the Motul Gear 300. It was a lot easier to shift in the morning when the car was cold, than either stock or MT-90. But that's probably because the 300 is a slightly thinner oil.
Having said that, I thinking using synthetic fluids in the tranny and engine is a very good idea, especially if you go to the track or just drive your car hard. Just don't expect a big change in shifting smoothness.
Old Mar 1, 2009 | 06:34 AM
  #312
jamarr911's Avatar
yea ive actually driven around with the Amsoil gear lube for about 2000 miles now and I mean the only thing I can say is it's easier to shift when the car hasn't warmed up yet in this cold weather. Other than that I'd say the shift feel is basically the same as the stock oil.
Old Mar 21, 2009 | 01:08 AM
  #313
my06tc's Avatar
im going to buy the redline gear oil later and do the change...getting into reverse and sometimes 1st is hard..but once it warm up it fine..but i just wanna get rid of the noise when you shift..this stuff is suppose to let the gear go in smoorth so your not forcing it...but i dont use the clutch when i racing only when im getting into first gear did i say racing or should i say shifting fast..
Old Mar 24, 2009 | 02:00 AM
  #314
Drey's Avatar
Is it safe to use MT-90 for limited slip differential or should i get some Redline 75w90 and their friction modifier for LSD? I'm not sure what dealer put in there but I know its 80w90. I think its too thick and I really like Redline.
Old Mar 24, 2009 | 09:25 PM
  #315
web's Avatar
web
^The difference in 80W-90 and 75W-90 is negligible other than on cold starts. As soon as it gets to operating temperature, they are the exact same viscosity.
The friction modifier though, I'd use the one that specifies that it has it.
Old Mar 27, 2009 | 01:31 PM
  #316
gp1817's Avatar
does it matter if you engine is hot or cold when doing this change...
Old Mar 27, 2009 | 01:38 PM
  #317
Ace83's Avatar
Ronin Scion
yeah it matters, when its hot there is a change that you will get burned if not careful lol but other than that it shouldnt matter
Old Mar 30, 2009 | 03:30 PM
  #318
web's Avatar
web
If the engines "warm," it'll help to make sure as much of the old fluid comes out as possible. When warm, the fluid flows much easier so, more fluid will come out in less time.
Old Apr 15, 2009 | 02:30 PM
  #319
gp1817's Avatar
when you remove the reverse sensor plug do you have to remove the scew also or all you need is to remove the reverse sensor to fill..
then i would neeed 24 mm to remove the drain and fill plug correct
Old May 2, 2009 | 06:52 PM
  #320
rosedaleny806's Avatar
best thing I couls have ever done to my tc=)
