tC Tech and DIY Info for the Scion tC
Transmission Flush (Manual, Redline MT-90)
Old May 3, 2009 | 09:08 AM
  #321
SFTifoso's Avatar
Originally Posted by gp1817
when you remove the reverse sensor plug do you have to remove the scew also or all you need is to remove the reverse sensor to fill..
then i would neeed 24 mm to remove the drain and fill plug correct
You don't have to remove the sensor. You can easily get the fluid back in through the fill plug using a funnel with a long tube, a pump, or a bottle that comes with a nozzle. And yes it's 24 mm. Make sure you buy short/stubby style socket. A deep socket will not fit to remove the drain plug.
Also, replace the gaskets to avoid any future leaks. Torque for both the drain and filler plug is 36 ft/lbs. Lastly Make sure the car is leveled or else you might under-fill or overfill your tranny.
Old May 8, 2009 | 07:36 PM
  #322
my06tc's Avatar
using a pump is not easier............filling from top then wait until it drips from the fill hole is easier..you dont torque the bolts gotta do it hand tight until its nice and tight.....this mod is suppose to be a easy DIY with basic tools
Old May 9, 2009 | 12:39 AM
  #323
web's Avatar
web
97K miles later and 3 trans fluid changes, no leaks with hand tight snug feel and original ring gasket
The fill plug is the easiest and cheapest.
Old May 17, 2009 | 06:19 PM
  #324
SoulXquisite's Avatar
-im planning to do my tranny oil, is it ok to drain it into my used motor oil container, or should i not mix them and get a seperate container?
Old May 17, 2009 | 06:53 PM
  #325
rosedaleny806's Avatar
u can mix it In that no prob. its trash anyway. that's wat the performance shop by me did jus drain it in the motor oil waste container
Old May 17, 2009 | 07:30 PM
  #326
-sweet, imma head to the local auto store to pick some good clean tranny oil for a change-
Old May 17, 2009 | 08:21 PM
  #327
I got mine online 39 shipped for 3 bottles. unless u can find redline at the store then that's great too
Old May 17, 2009 | 09:18 PM
  #328
-well i dunno if it was gonna be redline, but ill keep that in mind then....
-lately been modding my car for the past coouple of months, hurt my wallet a bit
Old May 18, 2009 | 07:35 AM
  #329
whatever oil u choose stay away from Mobil1 or Royal Purple, I heard horrible stories about them. Redline, Eneos & Motul are great, but when its colder out with redline (what I have) its alil rougher to get into gears but nothing crazy till the car is full warmed up, and at a stop first tends to jam up a bit aswell as reverse, but that's completely normal, it happens even when u don't put in new synthetic oil
Old May 18, 2009 | 12:05 PM
  #330
my06tc's Avatar
thats not true about mobile 1......i use that in all my cars no problems at all.....most people on scionlife use mobile 1.....most stories you probably heear the oil is probably not comaptiable with their car or they dont know what they buying or how to use it..you cant go by other stories on a product you have to try for yourself to see if it works for you....all cars are different.....sure i heard good and bad stories about the tc but didnt base my opion on buying one on that i took both sides and bought the car to see for my self and everything ive heard about i havent seen yet you get my point
Old May 18, 2009 | 12:53 PM
  #331
yeah most people on scionlie use mobil1 for engine oil not tranny oil. for tranny the majority of people on SL use redline or royal purple. and what are u actually saying is not true?? I didn't even give examples or anything of how mobil1 Tranny oil is bad for u to agree or disagree. so what in fact are u saying is not true? Yes I use mobil1 but for engine oil and filters, nothing more then that, u jus completely disagreed with nothing, no examples of wat it does or anything. and now if u would like to know how mobil1 tranny oil is bad ill tell u, mobil1 makes the gears grind horribly, with any car, our cars and others every gear u shift in it grinds. this is why the best pair is Mobil1 engine oil and Redline tranny oil is the best. I use mobil1 on all my cars aswell just not tranny, ive owned my tc for over 4 yrs now I know wats right and wats wrong either from my point of view or otheres here on SL, have u ever tries using mobil1 tranny oil?
Old May 18, 2009 | 12:58 PM
  #332
u actually disagreed yet hav redline tranny oil in ur profile? u never used mobil1 ever yet defending it for our transmission. lulz
Old May 18, 2009 | 02:05 PM
  #333
my06tc's Avatar
yea agree mobile 1 motor oil and redline tranny oil is best from what i see for the tc....i havent tried anything else other then the OEM fluid....i do alot of research prior doing work to my car....majority of tc owners use Mobile 1 motor oil now i knoew that before i came on the forum cause i use it on my other cars but i been lokin for a great tranny oil and came upon here and read redline is one of the best oils for the tc.....like i said 1 on the best im sure theres others out there that could preform better but its good for now..i have not tried any other tranny oil other then OEM and redline...as far a motor oil ive had pennzoil..mobile 1...gastrol and others......but mobile 1 is the only one i used in the tc so far
Old May 18, 2009 | 03:36 PM
  #334
oh noo haha I would never knock on mobil1 motor oil but when I said I heard bad things about it I meant tranny oil, car grinds too much with mobil1. as of right now I have redline and mobil 1 for motor, I love the redline but my gears tend to jam up with colder weather. seems alil rougher like sumthings holding it back sumtimes to get into 1st and reverse. does that happen to u after u used redline?
Old May 18, 2009 | 09:46 PM
  #335
my06tc's Avatar
little misunderstanding thats all......after i use the redline there was less grinding going into reverse......sometimes i have to go into 1st and 2nd then reverse wil line up and go through but for the most part if you do it nice and easy ill be fine but if you change the cable bushing at the end of the tranny you should have even more crisper enguagements and easier to get into gears im goona pick up some Cable Bushing Set from Isotope that should compltet the gear package but like you said when the car is cold but i think thats when any stick little rought shifting but once everything is warmed up its fine.....
Right now mobile 1 motor oil and redline tranny oil...and mobile one oil filter i heard K&N is really good also...
Old May 18, 2009 | 10:07 PM
  #336
web's Avatar
web
Off topic catch:...
^don't waste your money on K&N oil filters. They are meant for high pressure applications where much higher oil psi is seen and filtering is limited (alcohol engines that are pretty much rebuilt each run). Stick with OEM style and you'll have MORE than enough filtering for a stock and even modified motor.
Royal Purple motor and gear oil for me.
Old May 18, 2009 | 10:50 PM
  #337
my gears jam up a lot idk y ever since I changed to redline, I think I might change to eneos or royal purple idk yet
Old May 19, 2009 | 12:23 AM
  #338
my06tc's Avatar
how many miles of using the redline... majority of the people that use it no problems but seems like few people here and there seem to have problems with it doesnt necessarly mean its the oil could be the bushing or something loose....ive had no problems
Old May 19, 2009 | 12:25 AM
  #339
tcday's Avatar
3 bottles of this right
Old May 19, 2009 | 01:28 AM
  #340
my06tc's Avatar
yea but only goona use about 2 full bottles plus half of the last bottle....
