Turbo Install (ZPI Stage 0)
Yeah, I'm definitely getting this kit installed professionally, "if" I decide to keep it when I get back. There's just too many problems popping up for me to feel entirely comfortable doing it even with an experienced friend.
Originally Posted by tikbhoy
dang, i just read 3 pages of frustration. Do you even think its worth the money after all this ? what happend to bolt ons...
Originally Posted by Kaeon
Originally Posted by unseen
if you clock the turbo just right, you can avoid the hitting of charge pipe to firewall. i dont know how i got so lucky, but when i clocked my turbo the second time, i aligned it just right where theres like 1/4 inch of space between the two. now theres no rubbing noise whatsoever...but thats the least of MY worries.
We have come to the conclusion the outlet flange is to long. Because If I clock my turbo back anymore it will be inside the fans lol, Kenny is sending me a new flange like tuesday or something like that. That should help if not I will just cut a little bit off the TB end...
dood good install procedure make sure all ur pipes r in ur couplers reall good ...if not it will let it hit the cowl ....n what ive seen no gasket sems to work best ..cuz of all the heat ..as well as everyone knows things tend to warp n if u dont have it reall good n tight i can blow them ...well man wish ya the best of luck gettin it runnin right ...now it takes a few miles for the ecm to change for the turbo thats on it ...wish ya the best ...rukus[/quote]
i was wondering what happened to the first O2 sensor that was connected to the header? is there a place in the turbo for it to be plugged in or what? if there isn't should you be getting a cell because of an unplugged O2 sensor?
Originally Posted by draven301
Doesn't the stage 0 kit get a CEL anyway?
No CEL at all.
Originally Posted by JT_Scion
p.s. for some reason the turbo looks alot smaller than i thought.. used to looking at T-88's on supras haha
What part of florida are you in Kaeon?
ugh i get to attempt this thursday....were gonna have 3 people working on it 1 to get the oil pan off and 2 to work on the engine its coming pre asslymbed and think it has hoses and everything already so hopeuflly wont take us too long. We will get the oil pan/header/battery taken off wendesday. Turbo comes in thursday we will start working on it as soon as it comes if not at 615. Kaeon I im'd you on aim so if you dont mind me askin you questions as we do it my aim was twcpheranndez but itll probably be peteyd tC at home. ScionDad has been a HUGE help on on me gathering this up and what not. So big thanks to him!
Originally Posted by mattssi
We just got done w/ the oil pan part. We just used a pick tool and a small screw driver and went around the side. wasn't bad at all
Just a little update for those who are following, I’m still waiting for my gaskets I ordered on the 27th to be shipped. I was told last Thursday they would be over-nighted to me but from what I hear the copper cutter crapped out or something, None the less when they arrive (If they do) I will have been waiting on them for 2 weeks, I wish I could post more on how the kit works for you guys, But I can't do that if the car isn’t running... Im out of a car right now because the one I was using my dad needs, I wish someone from zpi would of called me to let me know they wouldn’t be in on time, That way I could of maybe ordered from another company. But now being Monday Night even if I did order them I wouldn’t get them till Thursday or Friday, So I’m pretty much screwed for now, this is turning out horrible for me. I hope you guys have better luck with your Installs/Service then I have...
~ Kaeon
Sounds like my day so far!!! Pretty frustrated and so is my bro. Had to run to the store about 4 times so far to pick up misc nuts, bolts, clamps, tee's, bits, etc.
Right now everything is done, except I am short 1 coupler. So, I had a spare 2.5" that I cut in two but that didn't work. So, I'm going to see if a local shop can get me SOMETHING so I can get the car driveable - and then I'll order the rest of th items I need.
But, its looking good so far to spite all the friggin bumps
