xB Tech and DIY Info for the Scion xB
A/C Control Color Change
Old Mar 2, 2005 | 06:23 PM
  #101
tlspatt's Avatar
yeah, if you pull that off i would luv to see pics on how you did it... mounting location, size, wiring, etc etc etc. that's an awesome idea, but i have never attempted something like that. i am sure it would be a HUGE hit, sounds like the majority of people have the same pet peeve we do.
Old Mar 2, 2005 | 06:26 PM
  #102
tlspatt's Avatar
would it be too far of a road-trip to get you to help me do mine??? (ha ha). i'll buy the beer! (ha ha, from San Diego)
Old Mar 3, 2005 | 04:36 AM
  #103
hotbox05's Avatar
I think ywo would be needed to adequtely light up the area one below one above.
Old Mar 10, 2005 | 01:38 AM
  #104
mhungry's Avatar
Default Bulbs or LEDs
I've noticed a really bad tendency on boards, with people using "LED" when it's actually a lamp, and vice versa. There's a BIG difference in this... LEDs run on a much much lower voltage (i.e. 1.2 to 2.8ish) than the lamps, which are usually the automotive standard 12v. LAMPS can be tiny and look like LEDs almost but again, can be 12v. Lamps can be changed easy with condoms, but you can't simply toss an LED in a lamps' place because of the voltage difference.... So please.. everyone.. be clear which type you are talking about.
Old Mar 10, 2005 | 10:54 AM
  #105
hotbox05's Avatar
Default Re: Bulbs or LEDs
Yes but for the center console led holder and such the holder comes with resistored leds.
Old Mar 20, 2005 | 02:52 PM
  #106
whadah's Avatar
Can some post a picture of where the spring suppose to be located? The spring pop out and now the ac is not working after I put everything back. I've found the spring but don't know where it goes. Thanks.
Old Mar 27, 2005 | 03:42 AM
  #107
Toasterbox05's Avatar
Default ok....here are some of my led photos
What i did
used this tutorial to remove and take everything apart........
i used a file and filed the tips of my leds flat to defuse the beam.....important
then cut the + lead on my leds really short and added a 520 ohm resistor
then cut my - led lead short and put a tiny 90 degree anngle on it
soldier the negative in first buy passing it thought the back side, allowing it to hang
then used needle nose pliers to bend the resistor lead in a full u-turn cutting the
excess off then putting a tiny 90 degree bend in it soldiered it in
just for giggles i also changed the green led in my ac on/off button to white too
you can go to my web page to view pics,
http://www.dcustoms.0catch.com
just enter the site and go to scion page to see all the pics if you are in the kissimmee orlando area and need some help with this, hit me up well talk and i will try to help you out.
Old Mar 27, 2005 | 04:31 AM
  #108
justinb's Avatar
The little collored bulb condoms should be available from Autometer.
They use them to determine the illumination color of a lot of their gauges. Find a local shop that does a decent volume of autometer sales and they should have them.
You could also try www.summitracing.com since they sell a lot of autometer stuff.
For the guy with the blue cots producing green light - did you take off the stock yellow cot?
-Justin
Old Mar 27, 2005 | 02:01 PM
  #109
Default Re: Led holders
Originally Posted by Minsk99
Originally Posted by hotbox05
yeah too bad the ac lights arent 194 and with the gel covers the lights look like crap . i just got some good led holders that accept #74 bulbs so u can still switch colors. lemme try n find the link. it's from japan so it might take me a day.
Did you find led holders that work? I got some from superbrightleds.com but they were too big. If you have that website that would be most helpful.
I gotta get ahold of sean (mybox) he can get some more for about 5 or 10 dollars so I'll let ya know he's in our team so i'll find out soon.
That would be cool. I wasted some $ on the superbrite holders as well. I was ____ed so I took the bulbs out of the holders and tried soldering them in. Well... no go. I'm assuming it has to do with the fact that the circuit is carried by copper on the back of the white plastic thing that the stock bulbs twist into. Perhaps I'm not using enough heat on it because the 60/40 solder is beading off of it. Problem is that its really easy to melt the plastic and screw things up. Back to the red bulb covers for now.
there is a protective cover on the copper.......you must rough this up with by shoving a small wire brush in there and you your also try using flux separate from the solder
Old Mar 27, 2005 | 02:04 PM
  #110
Default by the way
my parts list
super bright leds (2)
520 ohm resistors (2)
solder
flux
1/16 heat shirnk tubing
tools
phillips screw driver
wire brush
file
soldering iron
PATIENCE
Old Mar 27, 2005 | 04:33 PM
  #111
whadah's Avatar
I've figured it out. It wasn't contacting it. Thanks.
Old Mar 30, 2005 | 04:48 PM
  #112
Scion05BOPxB's Avatar
saving post for later. Great info.
Old Apr 4, 2005 | 07:25 PM
  #113
MacMaster's Avatar
Hey everyone, for those who wouldn't have a freakin clue on how to replace the actual leds in the compartment, I have a picture by popular demand of what the box and the part number of the led condoms. These are not direct fit like the yellow ones on the original LED. These are the ones that fit perfectly into the hole as shown on page one on the acutal install. I just did the mod today after waiting weeks to see if my local autozone had them. They had the green ones, but NOOO they didn't have the blue ones. I finally waited two weeks and decided to try autozone again off of a gut feeling and I found the last blue one. Hopefully this helps all you guys who don't know the part number!! (Note - They aren't in the package, i forgot to take a pic beforehand)
Brand Name - Pilot
Name - Gel Cap Bulb Covers
UPC - 7-5755870825-3
Model number - WI-801B - blue, WI-801R - red, WI-801G - green and thats all i know that exists
Old Apr 5, 2005 | 06:06 AM
  #114
hotbox05's Avatar
those gel caps didnt do crap for me , a range of blue to green and almost whitish.
Old Apr 17, 2005 | 05:28 AM
  #115
scott-'s Avatar
sounds like a lot of dissappointments going on with the changing of the color..has there been a easier way to do it yet?
Old Apr 17, 2005 | 12:10 PM
  #116
hotbox05's Avatar
i used the superbrite led.com led holders and modified em they work perfectly.
Old Apr 20, 2005 | 06:36 PM
  #117
ontada2's Avatar
now has anyone changed the clock color? I want in to match my new climate control color.
Old May 3, 2005 | 09:54 PM
  #118
anyone been brave enough to attempt the radio color? if drop me a message
Old May 5, 2005 | 09:16 AM
  #119
hotbox05's Avatar
um wgee76 i believe is his name did a radio , I've done the clock , the clock require de-soldering and then resoldering different leds number 1106 or 1206. the clock has 4 leds. hope that helps
Old May 19, 2005 | 06:09 PM
  #120
ChewyChop's Avatar
I think I like justinb's method. It is a point of no return but effective and obtainable. I am still curious as to those that have replaced the bulb with an LED and holder. Can someone please post a picture of what you are using or a link to where they can be purchased?
Thanks
