How do I Remove the Parking Brake Handle?
Old Oct 30, 2004 | 12:21 AM
ericroadking's Avatar
Default How do I Remove the Parking Brake Handle?
I just got a Itchibahn orange leather parking brake handle and I don't know how to remove the stock one?
Help!
___
Old Oct 30, 2004 | 03:22 AM
kevinandjudy's Avatar
i bought the same one probably. i havent installed mine either. but from looking at it i think it goes over your old one. im going to have to modify my stock handle.
do you have any other ichibahn products installed yet.
i have a rs-1 hot lava and these guys are just about the only people puttin out orange flavored accessories
Old Oct 30, 2004 | 03:39 AM
fusionscion's Avatar
i got a chrome ebrake handle installed, and you have to either take the whole assembly out like i did, or juss dremel the plastic cover off.... u have to cut through bout a good quarter to a half inch of plastic...... the cleanest way is to take the center cup holder thing out, then take the two bolts out holding the ebrake assembly in place, and take out the little wires that connect to the assembly... then cut the plastic cover off, put everything back in place.... and finally install the new cover.... looks good when ur done though
Old Feb 7, 2007 | 01:36 AM
Iride_xB04's Avatar
u cant just pull it off, u have to cut it off. I tried everyone else tips but in the end i took my roto cutter tool thing to it and took it off
Old Feb 7, 2007 | 04:05 AM
Bartx7000's Avatar
KAD
I got mine off without destroying it. I heated it for a few min with a hair dryer and then twisted it. It turned some. I keep heating it and twisting it till it got loose and came off.
Old Feb 8, 2007 | 12:02 AM
Iride_xB04's Avatar
youre lucky I tried everything and it barely moved off at all
Old May 28, 2007 | 07:21 AM
Burnt_RS_4's Avatar
Default .
Just mutilate it and get it offf so you can put on the kool one.
Old Jun 1, 2007 | 12:02 AM
Iride_xB04's Avatar
^exactly what has to be done, couldnt have said it better haha
Old Jun 20, 2007 | 02:22 AM
ShadowB0X's Avatar
Don't mutilate it. Wrap it with a shop towl then grab it in a vise. Then use a heat gun to heat the handle up considerably. You can even heat the metal to conduct heat to where they handle meets the metal. Then just keep twisting. You'll eventually be able to start turning it and pull the handle off. You'll get it off in about 5 - 10 minutes this way and you'll have the handle saved in perfect condition in case you want to put it back on. This is how I did mine and it worked great.
Invertalon
Oct 26, 2010 12:28 AM
Sandiego xD owner
Scion xD ICE & Interior
Feb 11, 2010 08:46 PM
Duncan1
Dec 23, 2007 04:09 AM
phillytc
Mar 25, 2005 06:30 AM
rolex87
Oct 2, 2003 04:31 AM
