amp settings help
Old Dec 8, 2007 | 03:17 PM
jkois's Avatar
Default amp settings help
ok, i am installing an amp that will power the front and rear components that i have installed, not a sub. the amp is a blaupunkt THA475PNP. plug and play with the required adapter cables. hookup is not a problem. my question is the settings namely low pass on/off. high pass frequency seting, and voltage level settins. the high freq is selectable between 10-250hz. the voltage .3-8v.
i think the low pass should be turned off, is that correct? if so then i only have to adjust the high pass freq, correct?. that only leaves the voltage, there i am lost. am i doing this right, or am i completely lost?????
thanks for any assistance!!!!!
Old Dec 8, 2007 | 03:23 PM
trialsindude's Avatar
Strictly Scionized
Turn LP on adj. freq to about 80hz or lower, voltage you have to match that with the HU.
Old Dec 8, 2007 | 03:29 PM
jkois's Avatar
awesome. i have the stock 08 premium hu, not the one with the amp upgrade. would you happen to know where i can find out the voltage??
thanks for the quick response
Old Dec 8, 2007 | 03:33 PM
Strictly Scionized
You used a line converter right?
Old Dec 8, 2007 | 03:48 PM
jkois's Avatar
sorry, no comprende'. line converter??
all i have is the adapter cable to place to amp between the speakers and hu. with an extension cable. all research at blaupunkt and crutchfield showed that to be all that was needed. the manual says to adjust the input sensitivity to the output of the car system. don't i just need to know the output of the car system??
Old Dec 8, 2007 | 05:49 PM
jkois's Avatar
ok, it is installed and this is what my settings are, seems to be working ok. haven't cranked it up yet.
low pass switches OFF - sound was extremely muffled with these on.
voltage level about mid way between .3 and 8
high pass freq selector about 1/3 from 10 hz to 250 hz.
before i crank it up and blow it, anyone see a problem with these settings?? i never was any good at setting up an amp.
Old Dec 8, 2007 | 07:30 PM
rocketgyrl's Avatar
That seems like you've got it set up correctly. Feel free to lower the HP frequency a bit - but be careful with the volume ****! Listen for the speakers to tell you how loud and how low they can play comfortably.
Old Dec 8, 2007 | 07:32 PM
Strictly Scionized
My bad, I was looking at what you wrote again, I didn't realize that you are connecting it to components.
LP OFF, do the high pass about about 80hz or above, listen to your speakers to see if there is any distortion. If not then the components can handle the 80hz HP.
Old Dec 8, 2007 | 08:22 PM
jkois's Avatar
excellent, thanks.
this was the simplest and quickest amp i have ever installed. didn't have to cut or tap a single wire. it sounds great!!!!!
Old Dec 9, 2007 | 05:47 AM
silverstreaktc's Avatar
use the force, Luke
Xaphoon
Scion tC 2G ICE & Interior
Apr 22, 2015 02:36 PM
stillcole
Apr 6, 2015 03:42 PM
TheSilencerTC
Feb 24, 2015 04:56 PM
koreysbox
12
Jan 11, 2004 05:32 AM
