omg please help, i need it fast :(
Old Mar 19, 2008 | 12:13 AM
elite-fusion's Avatar
Default omg please help, i need it fast :(
Tried to install my figs to go one with daylight lights n i followed the instructions but now for some reason my corners n leds in the headlights dont go on, any ideas? My guage still likghts up on one click of the headlight switch but cornetd n leds dont? Any ideas? I think its a fuse but i dont know which one...? Please help asap
Old Mar 19, 2008 | 01:01 AM
jurassic1's Avatar
whoa, slow down first off, you mean 'fogs' right? what kind of fog lights and whose instructions did you follow? the very first thing you gotta do is check all the fuses (both boxes)....
Old Mar 19, 2008 | 01:12 AM
combatsteve's Avatar
sounds like you blew a fuse. did anything spark or did you hear a faint pop anytime while you were doing it?
Old Mar 19, 2008 | 02:06 AM
BZinn1's Avatar
always disconnect the battery when doing wiring on a car.............probably popped the fuse to the lights........
Old Mar 19, 2008 | 02:13 AM
found the prob, it was the TAIL fuse, replaced it, and works fine now...but now have another problem, when trying to change gears with shifter, even while pressing the break paddle, it doesnt allow to switch from Park to drive, any ideas?
Old Mar 19, 2008 | 05:30 AM
Hyghgynx's Avatar
If you have an AT, the shifter is in the 'locked' position. This is what happens when you blow the fuse to the tails. It's a safety feature that doesn't allow you to drive without functioning tails. To remedy this, pop open the cap next to the shifter. (Use a small flat head screw driver.) You should be able to 'unlock' the feature and everything should be okay as long as you replaced the fuse.
Old Mar 19, 2008 | 07:24 AM
SquallLHeart's Avatar
yea.. if it still doesn't work after changing the fuse..
shoot... heheh.. you may have popped that fuse again.
Old Mar 19, 2008 | 05:15 PM
jurassic1's Avatar
hmmm, never knew that. you learn something everyday i guess. hope this solves your problem, elite-fusion
Old Mar 19, 2008 | 10:08 PM
Hyghgynx's Avatar
I didn't know either until it happened to a friend of mine. (I swear it wasn't me!!!)
Old Mar 21, 2008 | 01:32 AM
if you can't shift out of park then you popped the brake fuse or the tail fuse again. Do the brake lights come on when you hit the brake?
Old Mar 21, 2008 | 03:46 AM
i fixed it..it was the STOP fuse...thats the brake light fuse...because my tails turn on, but break lights didnt work...so ye...i found out that it was the STOP fuse....so replaced that..and that did the trick...and attempted to do the fogs with running lights and succeeded this time =D yay now it looks sexy =D thanks for all ya help guys, appriciate it
yupinmytC
22
Jul 27, 2024 07:08 PM
carid
Feb 10, 2019 10:46 PM
mxwes
Aug 30, 2015 09:11 PM
RokGoblin
Aug 11, 2015 02:45 PM
danaxb
Aug 10, 2015 06:33 PM
