retard timing with nitrous
Old Apr 6, 2008 | 02:15 AM
NA_TC_817's Avatar
Default retard timing with nitrous
im currently running a zex wet 55 shot wet kit and i would like to up it to a 75 but when i got my kit on the install manual it said if i was to run a 65 or 75 i would need to retard the timing ... is there anyone here running either a 65 or 75 and have not retard the timing and if you had any good or bad experience with it .. thanks
Old Apr 6, 2008 | 06:47 AM
DANIEL209's Avatar
By using the nitrous you increase cylinder pressure alot faster than normal so in order to keep the pressure from becoming too much too quick and blowing something to pieces in your motor you retard the timing to give you a little more time. I hope that makes sense. Just follow the instructions.
Old Apr 6, 2008 | 09:10 PM
NA_TC_817's Avatar
ok yea i was thinking the same thing .. reason i was asking is that the shop i purchase the kit from said i would be fine with 75 shot and not having to retard the timing i've would have to check the plugs and see if they are holding
Old Apr 6, 2008 | 10:33 PM
xezerax's Avatar
so have any nitrous users not retarded their timing? if you did what did you use?
Old Apr 7, 2008 | 02:44 AM
NA_TC_817's Avatar
im wanting to up my spray to a 75 but im looking into the
aem f/ic .. are you spraying xezerax ? and how much ?
Old Apr 7, 2008 | 05:30 AM
DANIEL209's Avatar
Oh , na tc 817 do not forget about running colder plugs than usual.
Old Apr 7, 2008 | 06:04 AM
xezerax's Avatar
im about to, everythings installed im just out of money til friday so ill be getting the bottle filled then. ill be starting with a 65 shot and havent touched my timing, ill let you know how it goes
spawnconnery
Dec 18, 2014 08:38 PM
darkshadowofxdeath
Nov 22, 2014 06:46 AM
eric_m
79
Mar 17, 2013 12:21 AM
Scionic
39
Jul 20, 2004 02:46 AM
KingLou
Nov 13, 2003 11:18 PM
